e manage
joeblitz
fitted one this week myself ....car started up but was lumpy and cut out .... i have upgraded my injectors to 850cc and have a twin blitz turbo kit fitted ...have checked over all the wiring all seems ok .... checked the set up on my laptop ..... ? has any one done a home set up as there is no one over here to do the setup ...:blink:
I take it you have set up the injector correction figure? and if its on a J spec then you need the injector adaptor.
:yeahthat:
Have you fitted one of these? The EMU cannot control the fueling properly on the 2JZGTE without the adapter installed.
15901504 GREDDY E-Manage Ultimate Injector Adapter 2
have the addaptor fitted all the wiring ok ..... i think my problem is on the set up on the laptop .... ive fitted a racelogic traction before so my wiring skills are ok .... ive fitted the wiring ...ecu ...emanage..addaptors.....traction unit ..... main harness ...in that order .............. :rolleyes: how do i get in touch with ian c .....
PM him :)
Ian C is back on Thursday. He can sell you a farily accurate base map, if you want a short cut.
Don't use the global correction facility it doesn't work as well as a proper map.
If you want to e-mail me your map and spec I can take a look.
PM me of you want.
  • 1 month later...
Guest Marvindjojo
hi
anyone out there have a greddy e manage ulitmate fitted to there supra ... :search:
Fitted one finally on a 1jzGTE, Mark II, JDM, .. not to steal your thread but..new in the Toyota scene and need some help. car starts and purrs like factory, everything works.. but now wanted to use the Greddy pressure sensor and I realized the huge trouble you have to go through..
Since this is my first post i'll just keep on searching for now..but any input would be appreciated....///All the way from Suriname South America.. where theres only one Greddy Ultimate installed and working!!!
