monkey76364 Posted May 22, 2007 Share Posted May 22, 2007 General discussion with some one: Tracking is way out on the Supra... what is best, I say 4 wheel laser alignment? what do you say ??? and why Link to comment Share on other sites More sharing options...
monkey76364 Posted May 22, 2007 Author Share Posted May 22, 2007 ???? Bump ! Link to comment Share on other sites More sharing options...
wallace9 Posted May 22, 2007 Share Posted May 22, 2007 I've got mine booked in for a 4 wheel laser allignment but don't know if its best because its the first time I will have had it done. Link to comment Share on other sites More sharing options...
RobSheffield Posted May 22, 2007 Share Posted May 22, 2007 Aside from laser alignment, what did you have in mind? Your question doesnt make much sense Link to comment Share on other sites More sharing options...
Kranz Posted May 22, 2007 Share Posted May 22, 2007 Go for the full optical 4 wheel alignment system.... the one where they hang sensors on the wheels and then can adjust tracker, camber, castor, KPI etc all at the same time. If your car's been lowered then it'd be good to get it all reset as it'll be way out if not done since lowering. I had mine done by Discount Tyres Direct in Worthing. The checking cost £50 IIRC but each adjustment cost £15... so with all the adjustments made it came out at £215 i think. I believe there's a place in North Wales (???) that does the same for club members at a lower cost. Check out the Lance W figures on MKIV.com and search on here for what people recommend. I went for Lance W setup as I have 17" wheels. No more scrubbing of the inside of the rear tyres. Link to comment Share on other sites More sharing options...
wallace9 Posted May 22, 2007 Share Posted May 22, 2007 I went for Lance W setup as I have 17" wheels. No more scrubbing of the inside of the rear tyres. Has your car been lowered?? Link to comment Share on other sites More sharing options...
Kranz Posted May 22, 2007 Share Posted May 22, 2007 Has your car been lowered?? Yep, any lower and it will be undriveable Link to comment Share on other sites More sharing options...
wallace9 Posted May 22, 2007 Share Posted May 22, 2007 Mines really low too and have been trying to decide if I should change change to LanceW settings. I'm running 17's too. Does it make much difference? Link to comment Share on other sites More sharing options...
Kranz Posted May 22, 2007 Share Posted May 22, 2007 I'd say yes, if only in tyre wear! Can't really compare the handling as I didn't get it on a track before & after, but felt more responsive to steering inputs. Link to comment Share on other sites More sharing options...
