Guest Glasgow_bhoy Posted May 15, 2007 Share Posted May 15, 2007 hi i took of my front dash today to put in a cd player and clipped off the cables etc...i put the dash and everything back together and when i started the engine the engine light comes on.....anyone got any ideas why, i was thinking possibly that the engine cable was not properly in before..........its driving fine with no problems Link to comment Share on other sites More sharing options...
edge Posted May 15, 2007 Share Posted May 15, 2007 Check for error codes Link to comment Share on other sites More sharing options...
Guest Glasgow_bhoy Posted May 15, 2007 Share Posted May 15, 2007 hi edge were do i find the error codes... Link to comment Share on other sites More sharing options...
edge Posted May 15, 2007 Share Posted May 15, 2007 Click on the words here > error codes Link to comment Share on other sites More sharing options...
edge Posted May 15, 2007 Share Posted May 15, 2007 If for some reason you cant see the hyper link the try this > http://www.mkivsupra.net/vbb/showthread.php?t=35920 Link to comment Share on other sites More sharing options...
Guest Glasgow_bhoy Posted May 15, 2007 Share Posted May 15, 2007 cheers mate Link to comment Share on other sites More sharing options...
Guest Glasgow_bhoy Posted May 15, 2007 Share Posted May 15, 2007 Basically when you put the key into start the car the light is on continously until you start it then dissapears. (as expected with most cars i guess) But it now comes on sometimes while I am driving and then stays on. When I shutdown and restart it dissapears... Link to comment Share on other sites More sharing options...
Thorin Posted May 16, 2007 Share Posted May 16, 2007 Only sometimes? Can we confirm which light it is that's on, the warning triangle in the middle? Any other lights? Airbag light stays on if you disconnect the dash without first disconnecting the battery, is it that? Link to comment Share on other sites More sharing options...
Bob Posted May 16, 2007 Share Posted May 16, 2007 When you say you "clipped the cables", exactly what do you mean and which cables did you do it to? Link to comment Share on other sites More sharing options...
lockys96 Posted May 16, 2007 Share Posted May 16, 2007 sounds like the active spoiler ecu Link to comment Share on other sites More sharing options...
stevie_b Posted May 16, 2007 Share Posted May 16, 2007 sounds like the active spoiler ecu That, or the speed sensor code 42 (my old favourite!). May have dislodged the speed converter behind the dash. Glasgow_bhoy: Check the error codes as described in this forum. It's really easy to do, and just takes a few seconds. When you turn the ignition key, make sure the immobiliser is off (i.e. car is NOT immobilised), otherwise the warning light might not illuminate at all. Link to comment Share on other sites More sharing options...
Greenauto Posted May 16, 2007 Share Posted May 16, 2007 I stupidly did the cd fitting without disconnecting the battery and now get the airbag light on constant, is there anyway to reset it? Link to comment Share on other sites More sharing options...
Heyrick Posted May 16, 2007 Share Posted May 16, 2007 I stupidly did the cd fitting without disconnecting the battery and now get the airbag light on constant, is there anyway to reset it? Mine was like this once I replaced the bulb that the dealer took out when he did the speedo conversion. Try this, post 2: Clicky Worked for me! Link to comment Share on other sites More sharing options...
Greenauto Posted May 16, 2007 Share Posted May 16, 2007 I'll give that a go. Doesn't sound too technical but I'll get someone to check the light for me. Cheers Dave Link to comment Share on other sites More sharing options...
stevie_b Posted May 16, 2007 Share Posted May 16, 2007 Greenauto: love the colour of your car (assume it's the one in the avatar). Is it standard? Link to comment Share on other sites More sharing options...
Greenauto Posted May 16, 2007 Share Posted May 16, 2007 Cheers Stevie, Yeah it is my car in my avatar. Must admit I'm pretty pleased with it and most folk in the know always tell me how rare it is to see one in green. I think its got the class of black but with enough colour and depth to really show the curves of the Sup. She's stock for the moment and i think she'll be staying that way till I can afford a nice kit a full respray and a full smoothing job done on her. Stock Rocks! Link to comment Share on other sites More sharing options...
