liam1 Posted May 7, 2007 Share Posted May 7, 2007 help needed new to modifiying ive got a j spec n/a ive been told the uk spec calipers are a good upgrade, are they easy to get hold of/expensive or does anyone recommend good calipers i havent got silly money to spend this is a second car and my modifiying will be done over a couple of years many thanks. Link to comment Share on other sites More sharing options...
TT-DEK Posted May 7, 2007 Share Posted May 7, 2007 If up-grading to uks, you will need the disks as well. All in best part of 500.00 for fronts? Second hand maybe all for the same money, if you lucky.. Link to comment Share on other sites More sharing options...
Nic Posted May 7, 2007 Share Posted May 7, 2007 help needed new to modifiying ive got a j spec n/a ive been told the uk spec calipers are a good upgrade, are they easy to get hold of/expensive or does anyone recommend good calipers i havent got silly money to spend this is a second car and my modifiying will be done over a couple of years many thanks. First of all find out what brakes you have fitted at the moment, many of the Japanese Supras came with the larger brakes fitted as standard too. If you're not sure post up pics so we can identify for you. The larger 4 pot front and 2 pot rear Supra brakes are the best value for money brakes you can fit, they'll give more than enough stopping power for any road use. Link to comment Share on other sites More sharing options...
Chiefgroover Posted May 8, 2007 Share Posted May 8, 2007 I have s/h front and rear calipers, upgraded discs, and top notch pads (essential) all going for £750. You'll be amazed at the difference in stopping distance/feel. Link to comment Share on other sites More sharing options...
JohnK Posted May 8, 2007 Share Posted May 8, 2007 Make sure your wheels will clear them Link to comment Share on other sites More sharing options...
