pistonbroke Posted May 5, 2007 Share Posted May 5, 2007 I was replacing the two small turbo coolant hoses that go from the elbow attached to the big top rad hose. The replacement hose I got interior diameter is too small and won't fit. The thing is, the old hoses are knackered and split when I removed them so are now unusable. Anyone able to help me ? Link to comment Share on other sites More sharing options...
markymark Posted May 5, 2007 Share Posted May 5, 2007 put the ends in boiling water for a while to soften up Link to comment Share on other sites More sharing options...
pistonbroke Posted May 5, 2007 Author Share Posted May 5, 2007 tried that. Link to comment Share on other sites More sharing options...
merckx Posted May 5, 2007 Share Posted May 5, 2007 Are they much smaller? Link to comment Share on other sites More sharing options...
pistonbroke Posted May 5, 2007 Author Share Posted May 5, 2007 the hose as a whole is the same diameter, so when I bought it I didn't think it would be a problem, however the center is about 2mm bigger on the one thats come off the car. I've tried heating it with a lighter but can only get it half way on before it so tight, it won't budge an inch. Link to comment Share on other sites More sharing options...
pistonbroke Posted May 5, 2007 Author Share Posted May 5, 2007 put the ends in boiling water for a while to soften up when you say put it in boiling water, I put it water after it had boiled in a kettle, should I boil it spaghetti stlye and leave it in a pan of water so its boiling constantly? Link to comment Share on other sites More sharing options...
Ric Posted May 5, 2007 Share Posted May 5, 2007 Pop to halfords 2morra and buy some bigger hosing? Link to comment Share on other sites More sharing options...
merckx Posted May 5, 2007 Share Posted May 5, 2007 I normally a hot air gun. Link to comment Share on other sites More sharing options...
markymark Posted May 6, 2007 Share Posted May 6, 2007 the hose as a whole is the same diameter, so when I bought it I didn't think it would be a problem, however the center is about 2mm bigger on the one thats come off the car. I've tried heating it with a lighter but can only get it half way on before it so tight, it won't budge an inch. In that case use a small amount of lube to help it on. when you say put it in boiling water, I put it water after it had boiled in a kettle, should I boil it spaghetti stlye and leave it in a pan of water so its boiling constantly? Just leave it in till it softens Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 6, 2007 Share Posted May 6, 2007 Buy some stock hoses, Toyota don't use rubbish, they fit and are cheapish. Link to comment Share on other sites More sharing options...
Suprash Posted May 6, 2007 Share Posted May 6, 2007 when you say put it in boiling water, I put it water after it had boiled in a kettle, should I boil it spaghetti stlye and leave it in a pan of water so its boiling constantly? Just make sure you dont put a bolognese sauce on it after, that'll wreck havoc on your engine bay when it dries...... Link to comment Share on other sites More sharing options...
uzthedentist Posted May 6, 2007 Share Posted May 6, 2007 i think theyre 6.5mm. wherabouts in london r u i can get u some Link to comment Share on other sites More sharing options...
supra_surj Posted May 6, 2007 Share Posted May 6, 2007 Sorry to hear your having probs mate. Let me know if I can help (not that I know much about these things!) lol Link to comment Share on other sites More sharing options...
pistonbroke Posted May 7, 2007 Author Share Posted May 7, 2007 i think theyre 6.5mm. wherabouts in london r u i can get u some I'm down in Bexleyheath Sorry to hear your having probs mate. Let me know if I can help (not that I know much about these things!) lol Cheers dude. Buy some stock hoses, Toyota don't use rubbish, they fit and are cheapish. Your right as ever CW, Just means the cars off the road now until at least Wednesday as they'll have to order the parts in when they open on Tuesday. I miss her already. Link to comment Share on other sites More sharing options...
