mikeyb10supra Posted April 22, 2007 Share Posted April 22, 2007 Im considering getting som j-specs refurbed with steel internals, my question is, is there any way of changing the stock WG at the same time as its going to be overpowered again with the hybrids..... Quote Link to comment Share on other sites More sharing options...
Kranz Posted April 22, 2007 Share Posted April 22, 2007 While its out the waste gate 'hole' can be opened up a bit. My JPS hybrids have a 'hole' size of 24mm ID and a valve head size of 33mm OD. I don't know if this is standard for J spec??? I guess you'd need to leave 3mm either side, so a 27mm ID hole may be ok... possibly even 28mm, but as the valve head is floating it isn't exactly central on the hole it needs to be a good overlap. Anyone know how big the UK spec wastegate is??? Quote Link to comment Share on other sites More sharing options...
