part_timer Posted April 20, 2007 Share Posted April 20, 2007 I had my brakes replaced last year and they have just started squeaking. not too much just every now and then. I had them apart myself prior to them being replaced and there were two metal plates on top of the pads, looked them up and they are anti-rattle shims. The machanic hasnt replaced these along with the pads so i was wondering if that was what is causing the squeaking? Quote Link to comment Share on other sites More sharing options...
baz Posted April 20, 2007 Share Posted April 20, 2007 yep, that will clause squeaking and knocking. best strip them down and replace the shims mate Quote Link to comment Share on other sites More sharing options...
part_timer Posted April 20, 2007 Author Share Posted April 20, 2007 Thanks baz. Has any one got a part number for the anti-rattle shims? Quote Link to comment Share on other sites More sharing options...
JohnK Posted April 20, 2007 Share Posted April 20, 2007 I dont have the shims in, I have had no problems. Quote Link to comment Share on other sites More sharing options...
Steve Posted April 20, 2007 Share Posted April 20, 2007 No problems here Quote Link to comment Share on other sites More sharing options...
Supe Posted April 20, 2007 Share Posted April 20, 2007 It's very common for the mechanic not bothering replacing these. If there missing then the breaks might squeal, although usually there ok without them Quote Link to comment Share on other sites More sharing options...
Pete Posted April 20, 2007 Share Posted April 20, 2007 CW left mine out as he says he founds on his Supra it helped give a more positive feel to the pedal. They sometimes squeel a little but it doesn't bother me. I kept them just in case though. Quote Link to comment Share on other sites More sharing options...
SimonB Posted April 20, 2007 Share Posted April 20, 2007 CW left mine out as he says he founds on his Supra it helped give a more positive feel to the pedal. They sometimes squeel a little but it doesn't bother me. I kept them just in case though. Especially if you don't fit new ones when you change pads, and they're not cheap. They are anti-squeel shims btw, not anti-rattle. The anti-rattle things are the springs that go on the back round the pins. Quote Link to comment Share on other sites More sharing options...
