Guest Phillw454 Posted April 18, 2007 Share Posted April 18, 2007 Hi Whever i try and paint something on my supra, usually plastics, even after iv primed it i try to spray it but i get little circles that just wont fill with paint so its like a bubble effect like the paint is being resisted? Sorry sounds silly i know, can anyone help with this? is it just grease? if yes how can i clean it properly? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted April 19, 2007 Share Posted April 19, 2007 More likely silicone contamination, contained in most polishes etc, you need to use spirit wipe frequently and use a little detergent when you wet flat, there are also some proprietary cleaning/flatting compounds you can use, and there is also an anti silicone paint additive. Quote Link to comment Share on other sites More sharing options...
Al Massey Posted April 19, 2007 Share Posted April 19, 2007 give it a good wash,and dry properly then sand it down a bit for the primer to take grip Quote Link to comment Share on other sites More sharing options...
csmadmatt Posted April 19, 2007 Share Posted April 19, 2007 As above but before you prime get some panel wipe to ensure all grease is off the car that way it wont happen. Quote Link to comment Share on other sites More sharing options...
Guest Phillw454 Posted April 19, 2007 Share Posted April 19, 2007 Ok thanks il remeber for next time:) Quote Link to comment Share on other sites More sharing options...
