computer help please
DannyW
Ive just bought a new laptop which i have connected to my home network.
Is there a way i can send files (photos, movies, music files etc) from the old laptop to the new one via my router?
Or is it a case of copying everything onto CD's?
The simplest method would be to create a network share on the machine with the music on, and map it as a network drive on the other machine. You can then copy the files off locally.
And how would one go about that my good fellow?
I'm poopoo kaka when it come to computers.
I don't know a great deal about Vista, but to share the files from the old laptop you can right click on the folder containing the files and select "Sharing and Security"
In the "Network sharing and security" section
either click the "If you understand ...." link and just enable sharing or select the Network Setup Wizard
enable Share this folder on the network
and give it a name
or Network Wizard:
Next
Next
you might need to ignore disconnected hardware
Other
First Option
Enter a name in the computer name e.g. oldlaptop
Next
Turn on file and printer sharing
Yes
Next
then
and give it a name e.g. musicshare
from the new laptop there should be a means to map a network drive somwhere - I don't know where
or you should be able to type the following into explorer
\\oldlaptop\musicshare
this should then bring up the music folder from the old laptop on the new laptop
and breathe ;)
Mike
