SUPRA2000 Posted August 7, 2004 Share Posted August 7, 2004 hi i was wondering what would happen if i did a ecu reset would everything still work or would i have problems with car Link to comment Share on other sites More sharing options...
geoffvalenti Posted August 7, 2004 Share Posted August 7, 2004 Everything would work fine. Its a recommended thing to do if you do any mods, so that the ECU can start with the factory settings. Link to comment Share on other sites More sharing options...
Terminator Posted August 7, 2004 Share Posted August 7, 2004 ECU reset is a common thing to do. Most frequent reason is to reset when changing from one fuel to another. The car will relearn new information after a few miles, you may notice the car run slightly rough for a few miles. Link to comment Share on other sites More sharing options...
SUPRA2000 Posted August 7, 2004 Author Share Posted August 7, 2004 what do you mean rough????? Link to comment Share on other sites More sharing options...
Terminator Posted August 7, 2004 Share Posted August 7, 2004 Not as smooth as you are used to:p Very slight hesitation, slightly less eager. We are talking very slight, and for a few miles while the car relearns all depends on you level of mods too. You may not even notice it. Link to comment Share on other sites More sharing options...
SUPRA2000 Posted August 7, 2004 Author Share Posted August 7, 2004 ok thanks i will try it is the fuse i need to take out dont i?? do you have any pic of which fuse?? Link to comment Share on other sites More sharing options...
richy2jz-gte Posted August 7, 2004 Share Posted August 7, 2004 ive tryed this (disconected bat and pulled fuse) made no diffrece what so ever Link to comment Share on other sites More sharing options...
Ian C Posted August 7, 2004 Share Posted August 7, 2004 If you take your fusebox lid off there is a diagram of the layout of all the fuses on the lid's underside. You want to whip out EFI No1 for 30 seconds. -Ian Link to comment Share on other sites More sharing options...
RICHARDA Posted August 7, 2004 Share Posted August 7, 2004 Ian, if you do not reset the ECU will it relearn anyway? Ta Rich Link to comment Share on other sites More sharing options...
SUPRA2000 Posted August 9, 2004 Author Share Posted August 9, 2004 would i need to switch ignition on and then remove the ecu or take battrey out then take the fuse out, please could you explain wot the procedure is and how to put the fuse back in thanks Link to comment Share on other sites More sharing options...
Ian C Posted August 9, 2004 Share Posted August 9, 2004 The ECU will slowly relearn, yes, but resetting it forces it to sort things out sharpish. Personally I never bother resetting the ECU for anything. With big injectors and cams the relearning procedure is ugly The procedure is easy, with the ignition off and keys out, take the EFI no1 fuse out with the handy fuse-grabby tool thats (hopefully) in your fuse box. Wait a minute, then jam it back in again. Put the fuse-grabby tool back and put the fuse box lid back on, start the car, let it idle for a bit, give it three mild rev-ups to let it learn how to catch the idle after a liftoff and then drive it for 10 miles or so. In my experience, that sorts out most of the coarse relearning, the rest will come as you tootle through town and boot it up clear roads -Ian Link to comment Share on other sites More sharing options...
SUPRA2000 Posted August 9, 2004 Author Share Posted August 9, 2004 thanks matey i will try that Link to comment Share on other sites More sharing options...
