Jacking up Supe?
Wazz72
Anyone recomend the best type of jack to use, and the best points to jack from? Tried at the jack points in the manual, with a 2 ton trolly jack, but the metal seam that runs the length of the car looked like it was going to bend.
The trolley jack should be ideal mate. Just make sure that you use a piece of wood between the jack and the jack point. You'll hear some cracking during lift but that will only be the jacking point embedding itself in to the wood.
