How to loose your cred instantly in a UK MKIV
SKI
Press the Horn!!!!!
Ahh what's going on with that, it sounds like a push bike horn.
Anyway... The question?
I've removed two horns, one from the front when you lift the bonnet up, another down the side by the air box and the freekin thing is still honkin, before I do something nasty where the hell is the last honker!!!!!!!!!!!!!!!!!!!
Cheers to anyone who can help me, one crap horn is bad enough but three seriously!!!! Someone at Toyotas havin' a laugh!
Matt, I got that one, but there is another somewhere, I can't for the hell of me find it. I've ripped out the one by the bonnet catch too, there must be another in the bumper maybe!? It sounds like it's coming from the front, I'm lost on this one M8!?!?!?!
SKI
Undo your radiator brackets at the top, Tilt her back a bit and see if you can see the wire coming through for it.
Be carfull cutting wires from there though as the ambient temperature sensor is around there too!
Might be an idea to find the correct wire colours from the manual for it?
Hope this helps
Scott
Jake, I thought the same as you, I fitted a good solid sounding air horn, but you can still hear that squawky horrible shrill of the last horn (if you can call it that).
Rest assured one way or another it will not be there tomorrow :)
