How much pressure should there be in the top hose coming off radiator?
cookci
I know on my car the top hose used to swell up and go rock solid but maybe that was due to the HG failure
On my girlfriends celica the same top hose (once the car is at operating temperature) the hose doesnt get pressured at all to the point i can almost squash it closed with my fingers when running! is that what mine should be like?
Im interested in what people think to this too, as mine does exactly the same, the top radiator hose swells and pressurises a fair bit. But, im pretty certain my headgasket is fine and dandy, as ive only travelled about 300metres since doing my single conversion, theres no white smoke whatso ever, plus my headgasket was fine before doing my single :)
Im thinking maybe i have an airlock or my (new trd style) radiator cap is a dud
:help:
Pump your tyres up to 15psi (or let them down) and press on the sidewall. This is what a top hose should feel like at MAXIMUM pressure... i.e. when the temperatures are at max (around 120 degrees C).
At idle with the engine up to temperature (87-ish deg C) is will be running much less pressure, so should be more squishy.
Rock solid sounds bad.
:help:
Is it as hard as you say it is?? (OOh err!). Some pressure is normal during normal running, but it should not be venting through the rad cap and ballooning the top hose.
Mines pretty rock solid;) , after 5minutes running too, im swaying towards a dodgy thermostat now actually, i'll have to take the bugger out and see what i find :D
Its probably fine mate. If you're not losing coolant & there's no bubbles in the header tank after a 'spirited' drive its probably ok.
Thermostat?? Either works (and all is ok) or it doesn't and sticks closed (boils over & head gasket is knackered) or sticks open (takes ages to warm up). Chuck it and get a new one if there is some doubt, cos it boils fast if stuck shut!!
Mine boils fast, like.. 5mins idling from cold, time for a new thermo i think :D ahh well, cheaper than a headgasket ;)
Thanks for the help matey :thumbs:
