Manic Posted July 11, 2004 Share Posted July 11, 2004 Having probs with air con switches so I took off dashboard cluster ie ashtray panel/air con panel and top dash section which has hazard switch etc. COuldnt find any probs so put it all back together. Now GULP when i try to start engine starter turns a bit then it clicks rapidly. HELP Any ideas what I may have pulled off accidentally? Matt Link to comment Share on other sites More sharing options...
Alex Posted July 11, 2004 Share Posted July 11, 2004 I would guess it's a flat battery. Did you have the interior light on whilst working on the car? Or the stereo? Anyway it's likely to be the battery of a loose connection to it. Link to comment Share on other sites More sharing options...
ChrisR Posted July 11, 2004 Share Posted July 11, 2004 Yep, i agree sounds lik a flat battery to me too. Link to comment Share on other sites More sharing options...
Manic Posted July 11, 2004 Author Share Posted July 11, 2004 Its possible I suppose but its always started perfect every time up until this morning. The fast clicking continues until I turn off ignition. Is there nothing I could have pulled off behind the dash to reproduce this? Matt Oh and yes I did have the light on and it took about 1 and half hours Link to comment Share on other sites More sharing options...
Manic Posted July 11, 2004 Author Share Posted July 11, 2004 In cars i've had before when the battery is flat as u turn the ignition the starter motor chugs then stops. This now is not turning but i get an electrical sounding fast continuos click. Matt Link to comment Share on other sites More sharing options...
Chase Posted July 11, 2004 Share Posted July 11, 2004 Can you try jump starting it? You'll know for definite then... Link to comment Share on other sites More sharing options...
Manic Posted July 11, 2004 Author Share Posted July 11, 2004 Im in a cul de sac at the bottom off a hill on my drive which is sloped but it would meaning rolling it backwards to bump start it( I dont fancy bumpin it backwards) so im gonna have to wait till the wife gets home and use jumps from her car. Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted July 11, 2004 Share Posted July 11, 2004 Did the same myself last weekend. Just fitted 4 Infinity speakers + tweeters, then whilst working on the side skirts noticed the speakers starting to clip at high bass. Thought i'd blown them, then noticed the interior light was very dim (a bit like myself) Link to comment Share on other sites More sharing options...
Manic Posted July 11, 2004 Author Share Posted July 11, 2004 Thanks for the replys, cars gonna have to wait now as F1 on so i'll try again l8r. Matt Link to comment Share on other sites More sharing options...
Grazer Posted July 11, 2004 Share Posted July 11, 2004 Definitely sounds like battery to me - I've done the same myself a couple of times while working on the stereo. Link to comment Share on other sites More sharing options...
SimonB Posted July 11, 2004 Share Posted July 11, 2004 Yep, deffo battery. What happens is that there's enough power to open the relay, then the starter motor draws all the power and so the relay closes again. Then there's enough power to open the relay again and the cycle starts again. Makes a clicking noise. Link to comment Share on other sites More sharing options...
Manic Posted July 11, 2004 Author Share Posted July 11, 2004 Right, Mrs just came home so connected jump leads, with other car running turned my ignition initially small amount of starter then clicks, 2nd attempt just clicks. I dont want to harbour the point but is there any other way I can confirm its battery ie lights dimming etc. Its just that its started perfecy every time since I got it and I do use it every day. Surely 1.5 hours wouldnt completely deadened the battery? Matt Link to comment Share on other sites More sharing options...
Ian C Posted July 11, 2004 Share Posted July 11, 2004 Try your wipers and electric windows - they will be sluggish. It's a bat flattery. -Ian Link to comment Share on other sites More sharing options...
Manic Posted July 11, 2004 Author Share Posted July 11, 2004 No the wipers and windows seem fine albeit slower up than down, but no different from normal? Link to comment Share on other sites More sharing options...
Manic Posted July 11, 2004 Author Share Posted July 11, 2004 Errr, guess what it was the battery HB005 from Halfords, Job done. Matt Link to comment Share on other sites More sharing options...
