Check yer pulleys guys
dude
  • Replies 50
Posted Images
Guest GARY GRAINGER
so glad you posted this up dude checked mine today and the outer part was coming away money saved i think. cheers.
Thanks dude , like they say prevention is better than cure !!!
Dude:flame Dev
Guest Terry S
We have another batch of the BL ones coming in next week. Most are spoken for but there are a few without homes yet.
  • 1 month later...
Originally posted by Peter Sharp
Did you know the one Titan sells Here is just a rebadged version of this one if you click on each photo you can see the patent numbers are the same....hehe
And neither use the stock belt !!!! nice when your in the back of beyond like Sheerness trying to buy a belt cause yours snapped !!!!
Dude:flame Dev
Out of interest, would fitting a lightened crank pulley, whilst already having a lightweight flywheel be a bad thing? I think I remember CW mentioning something about crank walk with a lightweight flywheel. Would this be accentuated with a lightened crank pulley?
I think my pulley is on it's way. The ring is split, (ahem) I mean the rubber ring, has a crack all the way around next to the outer ring.
  • 6 months later...
Digsy did a good post on this a while back, citing that you can't lighten a harmonic dampener because the weight has to be an specific amount in a specific place to dampen said harmonics. It's a bit like swapping your wheel balancing weights for lightweight ones...
-Ian
Guest Terry S
Dude Is right they are not underdriven, but you know any issues with underdriving. Never had a problem with them mate. e careful tho, ours are sfi approved.
Sorry to hijack, well not really, its still pulley based!
Terry / Dude, can you tell me how to remove the alternator pulley? I'm in the process of fitting some lightweight pulleys and this one doesn't seem so straightforward to take off and I don't want to risk damaging it by forcing it the wrong way.
I'd really appreciate any advice you can give me.
Ok guys, what i meant was, I am making a crank pulley using the same diameter (gearing) as the stocker although may make another with underdrive to be used in conjuction with an undersized waterpump pulley thus only effecting the less critical auxiliaries.
My question was, I have yet to see an aftermarket damped crank pulley, Dude says the BL one is, can you enlighten me?
Its easier with an Impact gun but the 'stud part of the alternator has an allen socket built into it , you need a deep throat :D , ring spanner and use the allen key to lock it all up .
Dude :thanku:
Well Mine did the "Lickity Split" thing last weekend. But my motto is if something breaks, its just an excuse to upgrade it!
So ive gon for:-
1. BL Crank Pulley $399 Shipped
2. HKS new style Cam pulleys
3. Billet Ancillery Pulleys
4. Greddy Cam belt
5. NEw anceillery belt (of course! as mine lika looks like hair extensions now)
6. New crank Bold
7. HKS 264 Cams
Just waiting for that old slow boat to sail in now...... ho hum....
Guest brads93
I just had this happen to my 1993 supra as well... While looking over this thread i wasn't able to figure out if this is something I, myself could do, or if i should bring it to a shop... Would doing it myself be to involved... Thanks for any and all the replys :thanks:
Guest brads93
thanks for the response.... I think i'll give it a try.... Some of my buddies at work also said it shouldn't be too difficult...we'll see what happens
