supradibbs Posted March 12, 2007 Share Posted March 12, 2007 holy shit thats one bloody old thread charlie Quote Link to comment Share on other sites More sharing options...
b_have Posted March 12, 2007 Share Posted March 12, 2007 Anyone? Surely this has been done before? Quote Link to comment Share on other sites More sharing options...
paul mac Posted March 12, 2007 Share Posted March 12, 2007 Well thats the end of my search and no conclusive answers on how to fool the ECU into thinking the trac is connected. Ive just finished making my own throttlebody, but with the trac gubbins disconnected, I lose manu mode and get the flashing lights. Any ideas gents? just in the process of doing this myself and thought i would cross this bridge when i got to it, i (without stating the obvious) presumed i would figure the wires and then short out the relevant ones, cant believe you cant find anything mate, as you say this must have been done before Quote Link to comment Share on other sites More sharing options...
b_have Posted March 12, 2007 Share Posted March 12, 2007 Did a search back to '92, lots of people asking this question but no answers. Must be a simple solution. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 12, 2007 Share Posted March 12, 2007 I will be in the same boat when i finish welding up the holes left by removing all the TC gubbins, what actually happens? error code? can the TC ECU be removed if its fed by the ECU? Quote Link to comment Share on other sites More sharing options...
colsoop Posted March 13, 2007 Share Posted March 13, 2007 I will be in the same boat when i finish welding up the holes left by removing all the TC gubbins, what actually happens? error code? can the TC ECU be removed if its fed by the ECU? It isn't so much an issue for you as your 6 speed. I have been running without mine for over a year now. I just got used to the flashing trc light. I was told that you can pull the bulb or remove the ecu enetirely to solve the light problem. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 13, 2007 Share Posted March 13, 2007 It isn't so much an issue for you as your 6 speed. I have been running without mine for over a year now. I just got used to the flashing trc light. I was told that you can pull the bulb or remove the ecu enetirely to solve the light problem. So there is no problems associated with just disconnecting the the trac control ECU, and finding it a new home on a shelf. Quote Link to comment Share on other sites More sharing options...
paul mac Posted June 18, 2007 Share Posted June 18, 2007 remove the ecu enetirely to solve the light problem. old thread still rumbling on, is the above the definative solution to this problem as i have just removed all the trac butterfly gubbins today, interestingly i run a Boostlogic built auto and was a bit dismayed at how harsh the gear changes were when i first got it i knew they were suposed to be "firm" but they were more of a "crash" on upshifts, removing the butterfly smoothed the changes to an acceptable level, i have'nt run the car yet just want to make sure i have no flashing lights Quote Link to comment Share on other sites More sharing options...
