TLicense Posted January 4, 2007 Share Posted January 4, 2007 LOL at this thread. Didn't I say that 1 pump wasn't man enough in this thread:- http://www.mkivsupra.net/vbb/showthread.php?t=93767 Also, using the electronic kit that myself and a guy at work are developing (as posted in that thread) you would know that a pump was failing BEFORE it failed completely. The idea being that you can do something about it before fuel pressure drops.... Link to comment Share on other sites More sharing options...
bondango Posted January 4, 2007 Share Posted January 4, 2007 LOL at this thread. Didn't I say that 1 pump wasn't man enough in this thread:- http://www.mkivsupra.net/vbb/showthread.php?t=93767 Also, using the electronic kit that myself and a guy at work are developing (as posted in that thread) you would know that a pump was failing BEFORE it failed completely. The idea being that you can do something about it before fuel pressure drops.... Tony did you find out if these were Do'able in a make 'loads of them' sense. I really like this idea but would combine it with a relay to cut power to the igniter as an absolute fail safe mechanism. Link to comment Share on other sites More sharing options...
Alex Posted January 4, 2007 Share Posted January 4, 2007 LOL at this thread. Didn't I say that 1 pump wasn't man enough in this thread:- http://www.mkivsupra.net/vbb/showthread.php?t=93767 Also, using the electronic kit that myself and a guy at work are developing (as posted in that thread) you would know that a pump was failing BEFORE it failed completely. The idea being that you can do something about it before fuel pressure drops.... Man enough for what though...I'm personally trying to work out lines in the sand for certain requirements. Link to comment Share on other sites More sharing options...
Mike B Posted January 4, 2007 Share Posted January 4, 2007 If that's a HKS knock Amp can I tap you up for your config and possibly wiring? Yes it's definately an hks knock amp.. but... You'll have to ask terry! It was set up and mapped for terry by Reg Riemer of RCTS in Canada, and I would be glad to give you any images, info or photo's that my layman ability can provide but I do not know the exact wiring schematics. Terry will know more specifics than I. I know it throttles back when it gets stressed (detects det) - usually only with bad fuel or (as yet untested) very high boost levels. It has a dial you can use to retard the ig with the dial to stop it interfering. full spec of the car; http://www.supravvti.com/ Link to comment Share on other sites More sharing options...
Mike B Posted January 4, 2007 Share Posted January 4, 2007 I never said the fuel could flow backwards through the failed pump. sorry dude - i need to learn to read! it was my first question when talking to terry, as I could forsee a possible problem.. Link to comment Share on other sites More sharing options...
Pig Posted January 4, 2007 Author Share Posted January 4, 2007 Im slightly confused here, sorry to be a retard when it comes to anything technical. If 1 walbro pump can pump 255 litres an hour, why would this not be man enough? If a car was on WOT for a whole hour would a 600 rwhp use approx this amount of fuel? Link to comment Share on other sites More sharing options...
Wez Posted January 4, 2007 Share Posted January 4, 2007 Supra only has a 70ltr tank, so approx 3.5 tanks of petrol in an hour if you use that theory. Link to comment Share on other sites More sharing options...
Wez Posted January 4, 2007 Share Posted January 4, 2007 Dont forget the Walbro only flows 255lph at 13.8v just below static which is 40psi, static is 43psi I think. edited just to add :- 1bar boost about 240lph at 13.8v 1.6bar boost about 210lph at 13.8v I didnt bother adding 12v figures as when running the car should see approx 13-14v. Link to comment Share on other sites More sharing options...
Pig Posted January 4, 2007 Author Share Posted January 4, 2007 Supra only has a 70ltr tank, so approx 3.5 tanks of petrol in an hour if you use that theory. You see my confusion then! But, could it actually be poss. "if" the car was @ WOT the whole time! Link to comment Share on other sites More sharing options...
bondango Posted January 4, 2007 Share Posted January 4, 2007 thats how much fuel flows to the rail from the tank, you have to work out how much fuel the injectors actually use, the rest is returned to the tank :-) The Walbro 255lph pump is often referred to the the walbro 550bhp pump by many many sellers http://www.tweakit.net/shop/product_info.php?products_id=1524 Id stick with it as a safe recommendation...1 255lpr pump for every 550bhp you want to make :-) Link to comment Share on other sites More sharing options...
Wez Posted January 4, 2007 Share Posted January 4, 2007 Id stick with it as a safe recommendation...1 255lpr pump for every 550bhp you want to make :-) Ian managed 630 at the fly on 1 Walbro. Link to comment Share on other sites More sharing options...
Alex Posted January 4, 2007 Share Posted January 4, 2007 I'll go with the 550BHP limit its safe, you can do more but is it worth the risk? This also allows for the pumps performance to degrade overtime without unduly ruining your enjoyment. Link to comment Share on other sites More sharing options...
Ian C Posted January 4, 2007 Share Posted January 4, 2007 At 90% capacity I'm happy, especially as it's rare I'll be on 1.4bar maximum revs. Like I said, I wouldn't go any higher, but don't read that as it's on the ragged edge now. -Ian Link to comment Share on other sites More sharing options...
Ian C Posted January 4, 2007 Share Posted January 4, 2007 Yes it's definately an hks knock amp.. but... You'll have to ask terry! It was set up and mapped for terry by Reg Riemer of RCTS in Canada, and I would be glad to give you any images, info or photo's that my layman ability can provide but I do not know the exact wiring schematics. Terry will know more specifics than I. I know it throttles back when it gets stressed (detects det) - usually only with bad fuel or (as yet untested) very high boost levels. It has a dial you can use to retard the ig with the dial to stop it interfering. full spec of the car; http://www.supravvti.com/ I'll check with El Tel, cheers. I may be asking you questions later I'll PM you if I do, save cluttering this thread up. -Ian Link to comment Share on other sites More sharing options...
Mike B Posted January 4, 2007 Share Posted January 4, 2007 I'll check with El Tel, cheers. I may be asking you questions later I'll PM you if I do, save cluttering this thread up. -Ian No worries, you helped me so many times - it's the least I can do! Link to comment Share on other sites More sharing options...
michael Posted January 4, 2007 Share Posted January 4, 2007 Any chance a mod can change the subject so it says "Dual" ? Link to comment Share on other sites More sharing options...
Pig Posted January 4, 2007 Author Share Posted January 4, 2007 Any chance a mod can change the subject so it says "Dual" ? There is definatly no change in you getting the fuel setup now Link to comment Share on other sites More sharing options...
michael Posted January 4, 2007 Share Posted January 4, 2007 I'm trying to help, I wanted to make you look clever so that you would sell me the kit you don't need Link to comment Share on other sites More sharing options...
michael Posted January 5, 2007 Share Posted January 5, 2007 LOL @ dool - took a while for me to notice that one Link to comment Share on other sites More sharing options...
