markjodrell Posted December 16, 2006 Share Posted December 16, 2006 I made a post last week regarding a pipe I found which was disconnected and sucking air,it was T cutted in to what I now believe to be the turbo pressure sensor.So I put a bolt in the added pipe to block it off , (only the added pipe, not the turbo pressure pipe. I thought this is where a boost guage could be fitted, but I was looking at another guys Supra and he has a BOV fitted here , see photo. Is this the correct place to T in a BOV and if so does or can the standard bov remain in place ?? Is the correct place to T in for a boost guage too ? Link to comment Share on other sites More sharing options...
Steviekid Posted December 16, 2006 Share Posted December 16, 2006 Is the correct place to T in for a boost guage too ? You could plum either a boost gauge or a BOV into it. Link to comment Share on other sites More sharing options...
Chris and Alana Posted December 16, 2006 Share Posted December 16, 2006 I changed my standard re-circ valve for a HKS SSQV. I took the old one out and put the BOV in its place. came with all the extra pipework I needed and with dodgy jap instructions with pictures that had been photocopied that many times it looked like a smudge but its pretty easy. I then 'T'd my boost gauge into the vacume tube off the BOV and it wors fine. Reads 12.5psi on stock tt which is about 0.82 bar I believe which should be accurate and it is also very responsive. I took the clock out the dash and put a 52mm boost gauge in there looks nice and tidy Link to comment Share on other sites More sharing options...
mikeyb10supra Posted December 16, 2006 Share Posted December 16, 2006 Dont T anything off the pipe shown in your pic use the one just to the left for your boost gauge below...hang on two tics and I will try and dig out a pic....if it pops off on boost your in all sorts of problems, much safer to use this one or your BOV actuator pipe http://img136.imageshack.us/img136/7162/boostgaugepickuppointvb6.jpg your BOV should replace the stock unit unless you want to weld to an intercooler pipe...that is if you have a FMIC Link to comment Share on other sites More sharing options...
Steviekid Posted December 16, 2006 Share Posted December 16, 2006 Dont T anything off the pipe shown in your pic Why not? I think you're confusing the hose pictured in the first post with the one supplying the pressure for the FPR which is on the opposite side of the intake, next to the pipe you've circled on your pic. Either hose circled in post one, or the one circled in your pic is fine to T into for a boost gauge/bov. Link to comment Share on other sites More sharing options...
Jim_1979 Posted December 16, 2006 Share Posted December 16, 2006 Mine is t-pieced into the pipe coming off the sensor thing circled in red. Is this safe enough?? I followed someones advice from here. http://img157.imageshack.us/img157/9454/boostgaugepickuppointvbaz7.gif Link to comment Share on other sites More sharing options...
Steviekid Posted December 16, 2006 Share Posted December 16, 2006 Mine is t-pieced into the pipe coming off the sensor thing circled in red. There isn't a vacuum hose in the assembly you've circled, only electrical cable. Can you recheck where it is? Link to comment Share on other sites More sharing options...
Jim_1979 Posted December 16, 2006 Share Posted December 16, 2006 there is mate.. jsut behind that cable there's a vac hose connected to whatever the sensor is. Link to comment Share on other sites More sharing options...
Thorin Posted December 16, 2006 Share Posted December 16, 2006 There isn't a vacuum hose in the assembly you've circled, only electrical cable. There most certainly is. there is mate.. jsut behind that cable there's a vac hose connected to whatever the sensor is. Leave it plumbed in there Link to comment Share on other sites More sharing options...
Jim_1979 Posted December 16, 2006 Share Posted December 16, 2006 cool, ta. Just wanted to make sure it was ok! Link to comment Share on other sites More sharing options...
Thorin Posted December 16, 2006 Share Posted December 16, 2006 http://mkiv.com/techarticles/boostguage/bg.htm Link to comment Share on other sites More sharing options...
Steviekid Posted December 16, 2006 Share Posted December 16, 2006 There most certainly is. Yeah, I'm being an idiot ignore me. Isn't that hose linked directly to the FPR though? If it pops off is there not massive potential for the car to run lean and blow up? Link to comment Share on other sites More sharing options...
Thorin Posted December 16, 2006 Share Posted December 16, 2006 Yeah, I'm being an idiot ignore me. Isn't that hose linked directly to the FPR though? If it pops off is there not massive potential for the car to run lean and blow up? It's the Turbo Pressure sensor (MAP). If that hose popped off there would be a potential risk of running lean if you continued to drive it hard... but you'd know about it pretty sharpish if it did pop off. There's no more danger of it popping off just plumbing a boost gauge in there than not though. Link to comment Share on other sites More sharing options...
Steviekid Posted December 16, 2006 Share Posted December 16, 2006 It's the Turbo Pressure sensor. Yeah but the hose immediately T's into the FPR pressure line. http://www.mkivsupra.net/vbb/showthread.php?t=46044&highlight=fpr Link to comment Share on other sites More sharing options...
Thorin Posted December 16, 2006 Share Posted December 16, 2006 Yeah but the hose immediately T's into the FPR pressure line. Yeah that's where the end of the "Y" bit goes off to. Link to comment Share on other sites More sharing options...
alan_blue Posted December 16, 2006 Share Posted December 16, 2006 so are we saying that the 1st pic is the safest position then? and also anyone know how to mount a 60mm guage in the air vent?? Link to comment Share on other sites More sharing options...
Steviekid Posted December 16, 2006 Share Posted December 16, 2006 so are we saying that the 1st pic is the safest position then? The one in the first pic and the pic in post 4 are fine. Having read the thread I posted the link to (this one) I personally woudn't use the one coming off the MAP sensor/FPR. Link to comment Share on other sites More sharing options...
alan_blue Posted December 16, 2006 Share Posted December 16, 2006 sorted then;) Link to comment Share on other sites More sharing options...
Thorin Posted December 16, 2006 Share Posted December 16, 2006 The one in the first pic and the pic in post 4 are fine. Having read the thread I posted the link to (this one) I personally woudn't use the one coming off the MAP sensor/FPR. I'd never seen that thread and it makes more sense to put it there (mine was done a very long time ago I should probably move it then). Incidentally I was also presuming that the yellow circled bit went back into the other side of the "Y" piece going by the comment in the first pic in this thread http://www.mkivsupra.net/vbb/showthread.php?t=35924 But that's incorrect as it's the hose just down and to the right of that one that goes to the Y section. Link to comment Share on other sites More sharing options...
Jim_1979 Posted December 16, 2006 Share Posted December 16, 2006 so where should it go??? .. lol Link to comment Share on other sites More sharing options...
alan_blue Posted December 16, 2006 Share Posted December 16, 2006 1st pic mate or 4th as said above Link to comment Share on other sites More sharing options...
markjodrell Posted December 16, 2006 Author Share Posted December 16, 2006 I made a post last week regarding a pipe I found which was disconnected and sucking air,it was T cutted in to what I now believe to be the turbo pressure sensor.So I put a bolt in the added pipe to block it off , (only the added pipe, not the turbo pressure pipe. I thought this is where a boost guage could be fitted, but I was looking at another guys Supra and he has a BOV fitted here , see photo. Is this the correct place to T in a BOV and if so does or can the standard bov remain in place ?? Is the correct place to T in for a boost guage too ? SOOOOOOO in conclusion, RE the first photo I posted at the beginning of this thread,,,,,, Is that okay to T in a BOV or a pressure guage?? AND if an extra BOV is put in place can the original be left in place ?????? This is the turbo pressure sensor pipe Link to comment Share on other sites More sharing options...
alan_blue Posted December 16, 2006 Share Posted December 16, 2006 yes mate Link to comment Share on other sites More sharing options...
markjodrell Posted December 16, 2006 Author Share Posted December 16, 2006 when an addition BOV is added can the original be left in place ?????? :search: :search: Link to comment Share on other sites More sharing options...
Jim_1979 Posted December 16, 2006 Share Posted December 16, 2006 so I should move where my gauge is plumbed in then? Link to comment Share on other sites More sharing options...
