mad_supra_21 Posted May 25, 2004 Share Posted May 25, 2004 I thought the limit for J-spec TT autos was 112mph,but mine seems to top out at 120mhp,is there a quick way (fuse to pull) which will stop this so i can have a quick blast to see what i can get it up 2,or do i have to spend money having it done properly:baa: Quote Link to comment Share on other sites More sharing options...
Digsy Posted May 26, 2004 Share Posted May 26, 2004 Its probably speedo error. The actual limit is 180km/h (111.8mph) but I've heard 120mph bandied around enough times to believe that this is the indicated speed when the limiter kicks in. You will have to buy a box of tricks from TRL Performance or somebody to get the limiter removed. Quote Link to comment Share on other sites More sharing options...
TLicense Posted May 26, 2004 Share Posted May 26, 2004 I'm going to be removing my speed limit defencer within the next week. I'm not sure what make it is, but if your interested you can have it for say £40? Let me know. Cheers Tony Quote Link to comment Share on other sites More sharing options...
Newgendesign Posted May 26, 2004 Share Posted May 26, 2004 Ref Speed limiter - Hi there! i would be interested in purchaseing your delimiter if it is for sale still. My car is limited to 120 too. How does it integrate into the current system - does it bypass or plug straight in to something? Jez Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted May 26, 2004 Share Posted May 26, 2004 There is a thread about this but if you take a gander at the info you will get by clicking on thors link above and looking on that site you will find out all you need to know. RE 120 mine also used to read 120 when it hit the limiter. I fitted GPS on mine whilst I was diagnosing a problem I had with my install and when indicating 120 i was only in fact doing 112 mph. Sounds like a common thing then if loads of other people have the same. Quote Link to comment Share on other sites More sharing options...
TLicense Posted May 26, 2004 Share Posted May 26, 2004 Originally posted by Newgendesign Ref Speed limiter - Hi there! i would be interested in purchaseing your delimiter if it is for sale still. My car is limited to 120 too. How does it integrate into the current system - does it bypass or plug straight in to something? Jez Basically you wire in your current speed signal wire, and then the output wire you connect to the ECU where your now going to speed limit defencer, old speed signal wire used to go. I think it also needs a 12volt and a ground. Not sure. Will get full spec when I remove it. Probably over the weekend. Hope that helps Tony Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted May 26, 2004 Share Posted May 26, 2004 Originally posted by TLicense Basically you wire in your current speed signal wire, and then the output wire you connect to the ECU where your now going to speed limit defencer, old speed signal wire used to go. I think it also needs a 12volt and a ground. Not sure. Will get full spec when I remove it. Probably over the weekend. Hope that helps Tony 12 volt powers the thing the TRL instruction webpage tells you where to get the 12 volts from. TRL wiring for 12 volts The wire that carries the speed signal into the ecu looks like this (after you chop it obviously) pic of ecu This download if it works should explain the whole thing again from TRL dsc.exe Quote Link to comment Share on other sites More sharing options...
lightwave Posted May 29, 2004 Share Posted May 29, 2004 Hi, Just realised when reading this thread that my car is also limited to 120mph. I worked out by reading the speedo and doing some maths while VERY bored going down the M3 with cruise control that the car doesn't display the correct speed at all... is anyone else's like this? When the car reads 30mph, it seems too slow. I worked out when it reads 35mph it's in fact doing 30mph. For motorway speeds, when it reads 95mph, it's doing just over 80mph. Is this a common problem? Anyone else have/notice this? I might try and borrow a GPS unit and test it. If this is the case, surely it's easy enough to just replace the speedo when a new dial that has adjusted measurements on it? I wonder if the Envy customised ones for £90 will read the correct speeds or if I can ask for it to be customised to adjust for it. I have a lot to ponder it seems. Quote Link to comment Share on other sites More sharing options...
ChrisR Posted May 29, 2004 Share Posted May 29, 2004 Ive heard a few people say there speedo's are 5MPH across the range. Both my GT-Four and Supra are. I checked them against my Snooper GPS. I have just replaced the dials in the GT-Four so i recalibrated it to read correctly (move the needle postion basically) its now perfect right up to 80 ish and then goes a little out. At higher speeds i think there will always be some inconsistency. My Supra was limited to 120 but was solved with a TRL jobbie. Cant really advise on fitting as it was done for me, but fitting a TRL unit is the answer. Quote Link to comment Share on other sites More sharing options...
lightwave Posted May 29, 2004 Share Posted May 29, 2004 When you say "move the needle position", how did you go about that? The needle calibrates itself to zero, doesn't it? How would I adjust it? Though it DOES need adjusting. Thanks for the confirmation though! Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted May 29, 2004 Share Posted May 29, 2004 The calibration can be done easily with the trl box which also delimits the car for you as well. Move the soop needle at your peril!!! When you take it off it has a tendency to move. Do a search there are several people on here that removed needles to change dial faces and ended up with way out zero speed readings. RE aftermarket dials as far as I am aware they are just direct replacements for stock items and as such will have precisely the same placement for the numbers. Getting new ones made to measure for individual cars is financially not an option. Quote Link to comment Share on other sites More sharing options...
lightwave Posted May 29, 2004 Share Posted May 29, 2004 You guys are cool, thanks. (As IF there was any question...) One last lame-ass question, what's a TRL box and where do I get one? Obviously I'll do my own research, but any info about it would be great from anyone that's got/used one. Thanks a bunch guys. Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted May 29, 2004 Share Posted May 29, 2004 TRLPerformance, sell them, they are on here.... queue..... your from southampton come along to bmth meet in june, theres a thread on it Quote Link to comment Share on other sites More sharing options...
lightwave Posted May 29, 2004 Share Posted May 29, 2004 Nevermind, I found it - phoned up... ordered one. Quote Link to comment Share on other sites More sharing options...
lightwave Posted May 29, 2004 Share Posted May 29, 2004 I'll have a look at that thread on the meet later. Nice one. I'll see if Jake's going. He's around here somewhere. Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 29, 2004 Share Posted May 29, 2004 I also have a (early version) SLD for sale now if anyone is interested. -Ian Quote Link to comment Share on other sites More sharing options...
Castle Posted June 28, 2004 Share Posted June 28, 2004 I'm just about to check whether i've been de limited or if it's playing up but what panel do i want to look behind, any directions please.... Quote Link to comment Share on other sites More sharing options...
Jake Posted June 28, 2004 Share Posted June 28, 2004 Originally posted by Castle I'm just about to check whether i've been de limited or if it's playing up but what panel do i want to look behind, any directions please.... Under the carpet where your passenger's feet would be there is large black plastic cover. Under that cover is the ECU and this is where a SLD would most likely be connected. It should be pretty obvious to spot once you've got the ECU exposed. Quote Link to comment Share on other sites More sharing options...
lightwave Posted June 28, 2004 Share Posted June 28, 2004 Originally posted by Jake ...once you've got the ECU exposed. Which I still need to do. Quote Link to comment Share on other sites More sharing options...
