A to Z of tuning
bungy
With a tt and cash but a wallet tighter than a nun's chuff, I was hoping to tap into the knowledge available to see what mods to do in what order and best products for results. The car has an induction kit and standard exhaust including cats. Where do I start on the hunt for BHP. I look forward to your replies and will post results as I complete each stage. I would like a solid but safe 400 as a target.
Thats alright if you understand the term bpu but there are some of us new to soops, was kind of hoping for someone helpful.
excuse him he was taking the mick as these posts come up regular, search for BPU and what it consists of, if you have any questions about it post up here.
Yes
For BPU you'll be looking at:
Double decat
Uprated fuel Pump
Free flowing cat back exhaust
Colder Plugs
FCD
Boost Gauge
Restrictor ring (if J-spec) max 1.2bar
With all that you'll be looking at around 380bhp at the flywheel.
If you want more then you'll be looking for :
Uprated FPR
Bigger Injectors
Fuel management
Hairier cams
FMIC
co2/water spray
The list goes on, and once of the slippery slope you'll find it hard to get off :D ;)
Thanks for the positive and i'll check out BPU. The induction kit was on when I bought the car. Would it be beneficial to source a standard air box to go back on.
Yes stock airbox back on! Not so many on here rate induction kits on the TT for performance!
Excuse Martin, he's a trained newbie killer ;)
As C1 says:
Double decat
Uprated fuel Pump
Colder Plugs
FCD
Boost Gauge
Stock Air Box with TRD Panel Filter or decent induction kit. For example HKS = Rubbish, Apexi or Power Enterprise = much better
That will certainly do nicely.
Gaz.
With it well deducted i don't think its worse performance........its more a question of poor filtration and the long term effects on the engine (particularly the turbos). Ie the possible small gain from having a aftermarket induction kit is outweighed by the possible problems.......
You want helpful? Look at the search button up above. More help than you'll ever need and it won't talk back to you either.
Use the search to button to find out how to put people on 'ignore'.
See? Helpful to a fault.:rolleyes:
Crikey mate! Yes, the question of
"How can I mod my Supra to make it go faster ?"
comes up alot. And yes, the answer for a TT - is nearly always BPU. And yes, nearly everything you might want to know is found with the search button.
But - as a trader on this forum for the good the members .. might be a good idea to remember that next a newbie posts up a question.
Now, ease off abit eh ?
