bungy Posted November 23, 2006 Share Posted November 23, 2006 Well I suffered the torment of oil filter replacement today and as such really keen to reposition. How difficult is the job and can anyone recommend a product. Thanks in advance. Link to comment Share on other sites More sharing options...
supra matt Posted November 23, 2006 Share Posted November 23, 2006 i got the greedy one mate alot of people slat it! but i had no problems with it and its so much easyer to do now . Link to comment Share on other sites More sharing options...
silvershark44 Posted November 23, 2006 Share Posted November 23, 2006 I dont get whats so hard?? I can reach in and get it fine, from both engine bay and underneith? Link to comment Share on other sites More sharing options...
bungy Posted November 23, 2006 Author Share Posted November 23, 2006 You must have bendy weasel arms because mine are bruised from reaching in from above. I did have the car up to try and do it from beneath but no easier so battled on from above. Where is the position to relocate the filter to. Dropping the oil was no problem. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 23, 2006 Share Posted November 23, 2006 Did you move the power steering res? much easier Link to comment Share on other sites More sharing options...
bungy Posted November 23, 2006 Author Share Posted November 23, 2006 I was going to but did not want to stress the pipes and cause more problems by bending them. Is this the way ahead for an easier filter change then and i'm just a bit dim. Link to comment Share on other sites More sharing options...
bignum Posted November 23, 2006 Share Posted November 23, 2006 or move the triangle shaped plate underneath, 4 bolts,, easy:) Link to comment Share on other sites More sharing options...
silvershark44 Posted November 23, 2006 Share Posted November 23, 2006 doing from above you need to remove the battery. Underneith people make the mistake of doing it in the wrong place, you need to go back right under the passenger side of the car and reach forward through, there is a massive gap and very easy. Use a plastic bag to unscrew it and drop it straight into the bag and your done, without spilling any oil! I can see oil filter relocation as being better, however, it really isnt overly nessessary. Link to comment Share on other sites More sharing options...
bungy Posted November 23, 2006 Author Share Posted November 23, 2006 Thanks for the advice. I did look underneath to see where to reach in. The plastic bag is a top tip that will save alot of mess in the future. Just got to rag up the spill I already have. Link to comment Share on other sites More sharing options...
Terminator Posted November 24, 2006 Share Posted November 24, 2006 doing from above you need to remove the battery. Underneath people make the mistake of doing it in the wrong place, you need to go back right under the passenger side of the car and reach forward through, there is a massive gap and very easy. Use a plastic bag to unscrew it and drop it straight into the bag and your done, without spilling any oil! I can see oil filter relocation as being better, however, it really isnt overly necessary. What he said - from behind the wheel Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 24, 2006 Share Posted November 24, 2006 It's so easy on a ramp. Why fit a re location kit? Just pay a garage a pittance to change the oil and filter, a decent re location kit will pay for a LOT of oil and filter change labour bills... Link to comment Share on other sites More sharing options...
