Chris and Alana Posted November 23, 2006 Share Posted November 23, 2006 Does anyone else suffer from the material on the dash where the long thin heater vent for the windscreen is shrinking and leaving the horrible nasty yellow form exposed? Coz its a little bit ugly to say the least. Does anyone know a cure? Link to comment Share on other sites More sharing options...
Class One Posted November 23, 2006 Share Posted November 23, 2006 It's a common problem, and the only cure is black marker pen to cover the horrible stuff up. Link to comment Share on other sites More sharing options...
Chris and Alana Posted November 23, 2006 Author Share Posted November 23, 2006 lol, I already tried that on the side facing me when you sit in the car and yes it hides it but I cant get the god dam pen on the site you can see from the outside (which is the worst side) its just one of those anoying things that people dont notice but you know its there Link to comment Share on other sites More sharing options...
Kranz Posted November 23, 2006 Share Posted November 23, 2006 Pull the plastic bit out and put it back in but not so far Covers the foam bit nicely. Link to comment Share on other sites More sharing options...
Chris and Alana Posted November 23, 2006 Author Share Posted November 23, 2006 Thanks haven`t tried that one yet will give it ago , does it pull off easily ? Link to comment Share on other sites More sharing options...
DamanC Posted November 23, 2006 Share Posted November 23, 2006 Halfords do dash repair kits, i have no idea if they are any good thou. Link to comment Share on other sites More sharing options...
Kranz Posted November 23, 2006 Share Posted November 23, 2006 Yep, two fingers in one end. Pull up & wiggle a bit and it pops out of the clips. Keep doing this down to the other end. While its out you may be able to push the foam down with something (being careful of the windscreen) or even use some black gaffa tape and tape it down??? Or use some black silicone sealant to fill in the gaps before refitting the vent? I just re-seated the air vent over it so it covered the mess. Link to comment Share on other sites More sharing options...
RedM Posted November 23, 2006 Share Posted November 23, 2006 Have you tried resetting the ECU? Link to comment Share on other sites More sharing options...
Kranz Posted November 23, 2006 Share Posted November 23, 2006 Have you tried resetting the ECU? :p Never known it to fix trim problems, other than injection or ignition trim Link to comment Share on other sites More sharing options...
Schtuv Posted November 23, 2006 Share Posted November 23, 2006 Pull the plastic bit out and put it back in but not so far Covers the foam bit nicely. Yup - that worked for me Just have to pop it up again after I clean the dash, each time ... Link to comment Share on other sites More sharing options...
RedM Posted November 23, 2006 Share Posted November 23, 2006 :p Never known it to fix trim problems, other than injection or ignition trim I thought resetting the ECU cured everything. Link to comment Share on other sites More sharing options...
Chris and Alana Posted November 23, 2006 Author Share Posted November 23, 2006 guys I'll give it ago the next time I get a bit of free time and I might eventually get rid of the yellow stuff Link to comment Share on other sites More sharing options...
Ian C Posted November 23, 2006 Share Posted November 23, 2006 Have you tried resetting the ECU? Link to comment Share on other sites More sharing options...
blitz supra Posted November 23, 2006 Share Posted November 23, 2006 It's a common problem, and the only cure is black marker pen to cover the horrible stuff up. Blimey i was just thinking of doing that today!!! weird Link to comment Share on other sites More sharing options...
TRD3000GT Posted November 23, 2006 Share Posted November 23, 2006 Recover the dash in Alcantara Link to comment Share on other sites More sharing options...
RedM Posted November 23, 2006 Share Posted November 23, 2006 Recover the dash in Alcantara Where's that? Link to comment Share on other sites More sharing options...
TRD3000GT Posted November 23, 2006 Share Posted November 23, 2006 Where's that? muppet http://www.alcantara.com/ Link to comment Share on other sites More sharing options...
RedM Posted November 23, 2006 Share Posted November 23, 2006 muppet http://www.alcantara.com/ I did know TBH. Just joking about. Link to comment Share on other sites More sharing options...
TRD3000GT Posted November 23, 2006 Share Posted November 23, 2006 I did know TBH. Just joking about. I know.. But I get pleasure out of making people look stupid Link to comment Share on other sites More sharing options...
RedM Posted November 23, 2006 Share Posted November 23, 2006 I know.. But I get pleasure out of making people look stupid Me too. Link to comment Share on other sites More sharing options...
Charlotte Posted November 23, 2006 Share Posted November 23, 2006 Me too. Ohhh is that what it is? Link to comment Share on other sites More sharing options...
swandip Posted November 23, 2006 Share Posted November 23, 2006 pull the vent out and reset it not so far in, works fine but NOT perfect. Link to comment Share on other sites More sharing options...
Kranz Posted November 23, 2006 Share Posted November 23, 2006 pull the vent out and reset it not so far in, works fine but NOT perfect. Do I hear an echo??? Link to comment Share on other sites More sharing options...
swandip Posted November 23, 2006 Share Posted November 23, 2006 just saying it worked for me also!! Link to comment Share on other sites More sharing options...
