Do I need a FCD
Chris and Alana
Thanks for the link. I know it will only hit fuel cut if I create over 1 bar of boost and from searching threads if you remove both cats the turbos can run upto 1.5 bar uncontrollably so you fit a restrictor ring to help keep it at about 1.2 bar. however If I keep the first cat as a restrictor to stop overboosting incontrollably what boost will my tubbies create, will it come close to or more than 1 bar? thanks for the help.
