Tiptronic
wile e coyote
No more faults with the Tip than the standard Auto it's based on....it's just an electronics upgrade.
1 word of caution though. The Tip can be difficult to get to change gear properly after a Speed Delimiter/Converter is fitted. I'd do some research in this area.
Only over 120 mph and at full throttle though. Mine doesn't want to change up unless you back off the throttle a bit and will drop down again if you (for example) floor it at 150 to see what happens.
