INDYPWR Posted November 14, 2006 Share Posted November 14, 2006 hey mates! was wondering what other things involved if you switch to USDM turbos ? i know you have to change injectors to 550's and change resistor box. tks for any help. Link to comment Share on other sites More sharing options...
Kranz Posted November 14, 2006 Share Posted November 14, 2006 US turbos are the same as UK turbos. You don't necessarily need the 550 injectors unless you're going above 1.2 bar boost, but if you do use them then you'll need a fuel controller. Link to comment Share on other sites More sharing options...
Kopite Posted November 14, 2006 Share Posted November 14, 2006 Different manifold and decat pipe too Link to comment Share on other sites More sharing options...
adi2009 Posted November 14, 2006 Share Posted November 14, 2006 Ya, pretty pointless swapping to UK turbos with 440cc injectors (assuming that you are planning on swapping turbos to attain higher power levels at BPU) since the injectors run out of flow at 1.2-1.3bar on jspec turbo s themselves. Link to comment Share on other sites More sharing options...
INDYPWR Posted November 15, 2006 Author Share Posted November 15, 2006 well, right now im hitting 1.2 bar daily. i do plan to change to 550's so can i achieve more boost than 1.2 bar ? i've got the whole exhaust manifold as well and a new TRD down pipe and resistor box. tks mates! Link to comment Share on other sites More sharing options...
