stevie_b Posted November 7, 2006 Share Posted November 7, 2006 I've done many searches trying to find what size tyres I should put on the standard 16" alloys in order to keep it stock. I've narrowed it down to this: Front: 225/50 16 Rear: 245/45 16 OR 245/50 16 Can anyone confirm which is the correct rear tyre size? What does the 2nd number (e.g. 45 or 50) actually signify? Thanks Link to comment Share on other sites More sharing options...
Ian W Posted November 7, 2006 Share Posted November 7, 2006 the second number signifies the ratio between the tyre width and side wall. iirc you want the 225/50 front and 245/45 on the rear. Link to comment Share on other sites More sharing options...
stevie_b Posted November 7, 2006 Author Share Posted November 7, 2006 Thank you. Does a higher number mean a wider or a narrower tyre? Link to comment Share on other sites More sharing options...
Ian W Posted November 7, 2006 Share Posted November 7, 2006 Thank you. Does a higher number mean a wider or a narrower tyre? higher first number means a wider tyre. higher second number means a larger/higher/wider side wall. Link to comment Share on other sites More sharing options...
Jake Posted November 7, 2006 Share Posted November 7, 2006 Front: 225/50 16 Rear: 245/45 16 OR 245/50 16 245/50/16 is wrong. On the rear of an NA the standard size is either 225/50/16 or 245/45/16 (both are standard sizes iirc) The 50 or 45 bit is the Aspect Ratio and represents the height of the sidewall as a percentage of the width. This is why a wider tyre needs a lower aspect ratio sidewall - so that the over all height remains about the same. Link to comment Share on other sites More sharing options...
Ian W Posted November 7, 2006 Share Posted November 7, 2006 245/50/16 is wrong. On the rear of an NA the standard size is either 225/50/16 or 245/45/16 (both are standard sizes iirc) The 50 or 45 bit is the Aspect Ratio and represents the height of the sidewall as a percentage of the width. This is why a wider tyre needs a lower aspect ratio sidewall - so that the over all height remains about the same. same as what i said then although, i'm sure some of the earlier cars actually came with 245/50/16's didn't they? i'm sure i can remember reading that somewhere.... Link to comment Share on other sites More sharing options...
Jake Posted November 7, 2006 Share Posted November 7, 2006 same as what i said then Yeah. I just said it better i'm sure some of the earlier cars actually came with 245/50/16's didn't they?Not that I know of. That size would have a larger rolling radius than the TTs 255/40/17. Seems unlikely. Link to comment Share on other sites More sharing options...
Ian W Posted November 7, 2006 Share Posted November 7, 2006 Not that I know of. That size would have a larger rolling radius than the TTs 255/40/17. Seems unlikely. unlikely as it may seem, Jake.... http://www.mkivsupra.net/vbb/showpost.php?p=86957&postcount=10 Link to comment Share on other sites More sharing options...
Guest Geneb Posted November 7, 2006 Share Posted November 7, 2006 225/16/14 fook that might be why i get a bit of noise from wheels scrubbing sometimes! mine came fitted with 275/35/17 rear and 235/40/17 front. need to change em i think thanks for the info. Link to comment Share on other sites More sharing options...
Graham S Posted November 7, 2006 Share Posted November 7, 2006 Steve, look inside the drivers door shut, pretty sure you have a toyota sticker giving proper sizes and pressures if i remember right, but i'd stay off the weird Jap import semi slick things this time!!! Haha! Link to comment Share on other sites More sharing options...
stevie_b Posted November 8, 2006 Author Share Posted November 8, 2006 Cheers for all the info guys! Graham, I've noticed that my tyres don't give the best of grip in the wet: do you reckon they're non-standard? (I bought the car with those on). I'm thinking of getting some Michelins from the wholesaler. Link to comment Share on other sites More sharing options...
Jake Posted November 8, 2006 Share Posted November 8, 2006 unlikely as it may seem, Jake.... http://www.mkivsupra.net/vbb/showpost.php?p=86957&postcount=10 Blimey that's an old one! Answers the question though. Cheers. 225/16/14 fook that might be why i get a bit of noise from wheels scrubbing sometimes! mine came fitted with 275/35/17 rear and 235/40/17 front. 225/16/14 ? What do you mean? 275/35/17 and 235/40/17 are about right. Shouldn't cause you any problems. Link to comment Share on other sites More sharing options...
Schtuv Posted November 8, 2006 Share Posted November 8, 2006 Steve, look inside the drivers door shut, pretty sure you have a toyota sticker giving proper sizes and pressures if i remember right, but i'd stay off the weird Jap import semi slick things this time!!! Haha! Attached - one picture of the toyota sticker for your viewing pleasure It's on a 1994 jspec NA ... I don't know if tyres changed over the years. Link to comment Share on other sites More sharing options...
Scooter Posted November 8, 2006 Share Posted November 8, 2006 It's on a 1994 jspec NA ... I don't know if tyres changed over the years. my old na definitely had that sticker..............i'm 99% sure that my facelift NA has one stating 245/45/16 though................ Link to comment Share on other sites More sharing options...
