what safc for na-t
bowk1uk
nearly finished my na-t conversion
just the bov to be fitted when the t piece arrives,
any sugestions on what fuel controller to go with ,thinking of apexi neo
is there anything else anyone recomends to run this safely as an every day car
will not be boosting more than 8psi,still on standard hg
hoping for around 320 to start, then if i get bored i will do the hg then who knows
kit cost me £880 shipped, then about another £500 for ic pipe ,new oil return line (did,nt like one with kit),flexi pipe for dp
still got to buy safc,etc
What engine management have you gone for?
dont think i need an engine management for this stage
was under the impresion an safc,boost gauge and air/fuel ratio gauge was enough to run safely
that was my orriginal question if this is enough to run with this
I would not try for 320hp on the standard injectors, you will be right on the ragged edge even if you buy a regulator and up the pressure, standard injectors are 330cc
what size injecters do you recomend, thought i was ok on standard for that power
