REQUIRE Supra Import TT front Discs
M4RK RZ
You could try your local Toyota dealership for OEM ones (ask the Yorkshire lads on here for the best one) or give Steve Manley a ring at Inchcape Toyota, Kidlington as I am sure he will courier them out. For aftermarket try one of the traders
Im not sure what size discs I hav at min ! aparently there are two different sizes . 296mm and 323mm.
I can get the standard 296mm for £77.18 each
323mm for £62.71 each
The larger ones are cheaper :rolleyes: typical eh!
Is there no where in the car documents that tells you the disc specs??
Post pics of your brakes, so we can see which you need, it is easy to tell the difference when you see the calipers.
lol - cheers guys !
What about discs that will fit straight on the jap spec (same size) but are drilled and/or grooved ?
I got a pic sorted for you - attached
That is a 2 pot front caliper, so your discs are 296mm diameter.
I can supply Project Mu 296mm discs, they cost a fair bit more than the stock discs though!
Project Mu SCR-Pro
Project Mu SCR
