ChrisSZ Posted October 19, 2006 Share Posted October 19, 2006 I'm gonna have to sourse some good spacers, i'm pretty sure that my wheels won't fit over UK spec brakes, and I don't really want to change my wheels. Was gonna go with the Ultralite versions, but I may have a look at the SRBPower ones too now. If you wanna have a look at a set pop round mate - I have them fitted front and rear Quote Link to comment Share on other sites More sharing options...
stupra Posted October 19, 2006 Share Posted October 19, 2006 If you wanna have a look at a set pop round mate - I have them fitted front and rear Nice one cheers Chris, let me know when it'll be ok for you mate. Quote Link to comment Share on other sites More sharing options...
absz Posted October 19, 2006 Share Posted October 19, 2006 You screw up the suspension geometry and subsequently the handling. You will also get through a lot of wheel bearings. i have 11's with negative offset and have no problems at all. no tramlining pulling or uneven wear, had a full alignment/caster/camber check done and everything was spot on Quote Link to comment Share on other sites More sharing options...
Nic Posted October 20, 2006 Share Posted October 20, 2006 i have 11's with negative offset and have no problems at all. no tramlining pulling or uneven wear, had a full alignment/caster/camber check done and everything was spot on The question was about 11.5's Quote Link to comment Share on other sites More sharing options...
ChrisSZ Posted October 20, 2006 Share Posted October 20, 2006 Nice one cheers Chris, let me know when it'll be ok for you mate. Probably gonna be around most of Sunday mate - taking the inlet cam out to have a looksee why it's stiff as buggery to turn:( Got my number? PM me and I'll send it over to you Quote Link to comment Share on other sites More sharing options...
lockys96 Posted October 20, 2006 Share Posted October 20, 2006 The question was about 11.5's so the extra .5inch is everything nic? in wheel terms before the funnys come in. ill go for a 11" rear then with a -30 offset Quote Link to comment Share on other sites More sharing options...
Nic Posted October 20, 2006 Share Posted October 20, 2006 so the extra .5inch is everything nic? in wheel terms before the funnys come in. ill go for a 11" rear then with a -30 offset No, I was just funning Quote Link to comment Share on other sites More sharing options...
lockys96 Posted October 20, 2006 Share Posted October 20, 2006 thats ok then. hope i dont rip through too many wheel bearings. dont want a 13" on the back Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted October 20, 2006 Share Posted October 20, 2006 It puts a bigger load on your wheel bearings. It's like having wrong-offset wheels. Your suspension geo will be slightly out, it may tramline more, wear tyres oddly, and catch the arch liner with the tyre at full lock. -Ian I can confirm to almost all of this Quote Link to comment Share on other sites More sharing options...
merckx Posted October 20, 2006 Share Posted October 20, 2006 The standard wheel studs should be ok with 5mm spacers From my experience if you put 5mm spacers over the existing studs you need to check your stud length. I had 4mm spacers on the rear which only gave me about 5mm of thread held by the wheel nuts! That's why I fitted longer studs. It will of course depend on the wheel you have fitted and how much aluminium you have between the nut seat and the face of the wheel which bolts to the hub. Quote Link to comment Share on other sites More sharing options...
ChrisSZ Posted October 20, 2006 Share Posted October 20, 2006 From my experience if you put 5mm spacers over the existing studs you need to check your stud length. It will of course depend on the wheel you have fitted and how much aluminium you have between the nut seat and the face of the wheel which bolts to the hub. Good point I forgot that the hubs on my rims are somewhat thinner than the standard ones therefore leaving a reasonable amount of thread even with 5mm spacers. My current spaces are thicker still so I now have longer studs to suit:d Quote Link to comment Share on other sites More sharing options...
merckx Posted October 20, 2006 Share Posted October 20, 2006 Good point I forgot that the hubs on my rims are somewhat thinner than the standard ones therefore leaving a reasonable amount of thread even with 5mm spacers. My current spaces are thicker still so I now have longer studs to suit:d The wheels I had fitted were crap anyway, glad to get rid of them. Quote Link to comment Share on other sites More sharing options...
stupra Posted October 20, 2006 Share Posted October 20, 2006 Chris, do you have any probs with the tyres rubbing on the rear arches, with the five mm spacer on the car ?, or have you had the arches rolled ? Quote Link to comment Share on other sites More sharing options...
merckx Posted October 20, 2006 Share Posted October 20, 2006 It totally depends on what offset wheels you have. Quote Link to comment Share on other sites More sharing options...
ChrisSZ Posted October 20, 2006 Share Posted October 20, 2006 Chris, do you have any probs with the tyres rubbing on the rear arches, with the five mm spacer on the car ?, or have you had the arches rolled ? No and no:Pling: (especially since the bugger won't go right now LOL) - no rubbing whatsoever and the rims sit nice and flush with the sides of the car Quote Link to comment Share on other sites More sharing options...
stupra Posted October 20, 2006 Share Posted October 20, 2006 No and no:Pling: (especially since the bugger won't go right now LOL) - no rubbing whatsoever and the rims sit nice and flush with the sides of the car You got your UK spec brakes on the car yet mate ?, if you have i'd like to see if my wheels will clear them with the 5mm spacers. Got a feeling I might need to get the arches rolled though, the wheels sit pretty flush with the arches already. Quote Link to comment Share on other sites More sharing options...
ChrisSZ Posted October 20, 2006 Share Posted October 20, 2006 Stupra - PM'd ya Quote Link to comment Share on other sites More sharing options...
