Another central heating question
Chris Wilson
The LCD (well I THINK it's an LCD screen) on the programmer has gone blank. It's not very old, it merely played up at first and if you rubbed a finger over it it came back on, now it's not doing this. Is there a trick to making LCD displays return, or do I need to spend money :( ?? Thanks. There's power and evrything to it, it's just the display screen, so I can't see to change times et cetera.
If you need a new programmer i may be able to sort you one out !
PM me if you do, may have a spare floating on my van :)
I think most programmers/ timeclocks are usually sealed units.
Other than changing the battery backup , or cleaning the contacts of the front to the backplate there normally isnt much else to do than "toss it in the bin".
Obviously replacing with the same, means only changing the front rather than messing about with the electrics on backplate.
Cheers
Ian
Mine died and was a complete unit that controlled the timers etc.
It was replaced for about £100. Very easy job. (on mine anyway)
Last time my boiler went wrong I bought the parts direct from a plumbing supplier - much cheaper.
