lui Posted October 6, 2006 Share Posted October 6, 2006 URGENT ADVICE NEEDED PLEASE AS THIS IS DOING MY HEAD IN Does the power steering reseroir cap got to be a air tight fit & not leak in any air once tighted Due to now I have fitted 2 power steering pumps & both failed within 30 miles. Once fitting power steering pump & bleed sytem everything was fine & all working perfect but once out on the road within 25 - 30 miles packed up again. Checked power steering reservoir cap on spare tank to discover when blocking off one feed to tank fitting piece of tube to other end & securing cap on top by blowing down the tube discovered air coming through cap. I reckon if air escaping through cap while driving along would put air back into system causing this problem. Main question is should the power steering resevior cap have air tight seal once tightened up And if cap is not air tight would it leak air into power steering system Many Thanks Lui Quote Link to comment Share on other sites More sharing options...
Homer Posted October 6, 2006 Share Posted October 6, 2006 Yes, it has to be air tight otherwise your pump will get overloaded. You can't bleed the system properly if there's a leak either. Can you please use normal text in the technical section, otherwise it'll get edited or bumped off to chat Quote Link to comment Share on other sites More sharing options...
lui Posted October 6, 2006 Author Share Posted October 6, 2006 Any one got any answers to question above please ??????????? Cheers Lui I myself reckon 99% powersteering reservior cap has to have air tight seal when tightened. Quote Link to comment Share on other sites More sharing options...
Chiefgroover Posted October 6, 2006 Share Posted October 6, 2006 I have had quite a bit of first hand experience with this problem. Sounds like your fluid is done, if so it will wreck the pumps and ruin the seals in the rack. I have a spare PAS pump somewhere if you need it. Having suffered the effects of overheating 10 year old fluid, I can assure you it will piss out when the pressure is on, and ruin your pump quickly. If a rack seal goes then you loose the ability to steer in one direction, and that could cost you your life. Drain the system, remove the rack and wash it out properly as when the pump dies small plastic bits travel through the system and stick in the rack. Personally I'd have it checked by someone with good experience in PAS racks. then rebuild and fit new fluid. Good luck! Quote Link to comment Share on other sites More sharing options...
Chiefgroover Posted October 6, 2006 Share Posted October 6, 2006 OH yeah and PAS system has a pressure cap, bit like a radiator idea. Under stress it will let the fluid out. Quote Link to comment Share on other sites More sharing options...
lui Posted October 6, 2006 Author Share Posted October 6, 2006 OH yeah and PAS system has a pressure cap, bit like a radiator idea. Under stress it will let the fluid out. Like i said my cap does not seal properly & i have tested this so if it does not make air tight seal will this cause air to get into system ??????????? Quote Link to comment Share on other sites More sharing options...
lui Posted October 6, 2006 Author Share Posted October 6, 2006 Anyway going to fit another PAS pump complete with new resevior cap that DOES NOT LEAK air & hope that this will cure the problem as I personally thinks that's it the dodgy not fully sealing cap thats causing all the problems As ive tested my cap & 500% it's leaking air & not fully sealing resovior tank & on this it's letting air back into system causing this stupid problem Quote Link to comment Share on other sites More sharing options...
Chiefgroover Posted October 8, 2006 Share Posted October 8, 2006 You need some breathing with the cap, have you ever noticed how much the level varies when the rack is turned from lock to lock?, the reservoir is designed to stop the fluid splashing out on corners. As I said before, It's a bit like your rad cap in ways. If it's under pressure it has to breath. Quote Link to comment Share on other sites More sharing options...
tango Posted December 31, 2006 Share Posted December 31, 2006 I have had quite a bit of first hand experience with this problem. Sounds like your fluid is done, if so it will wreck the pumps and ruin the seals in the rack. I have a spare PAS pump somewhere if you need it. Having suffered the effects of overheating 10 year old fluid, I can assure you it will piss out when the pressure is on, and ruin your pump quickly. If a rack seal goes then you loose the ability to steer in one direction, and that could cost you your life. Drain the system, remove the rack and wash it out properly as when the pump dies small plastic bits travel through the system and stick in the rack. Personally I'd have it checked by someone with good experience in PAS racks. then rebuild and fit new fluid. Good luck! Hi there, do you still have the pump available? how much? cheers Quote Link to comment Share on other sites More sharing options...
Chiefgroover Posted December 31, 2006 Share Posted December 31, 2006 I think I still have that pump in my garage, £80 plus post. I think thats cheap, I had a german ask me 600euro for a s/h one, and I had Paul E ask me about £160 for a s/h one no warranty. I gave £80 and will take £80. P.M. me if you want it. Quote Link to comment Share on other sites More sharing options...
lui Posted December 31, 2006 Author Share Posted December 31, 2006 I think I still have that pump in my garage, £80 plus post. I think thats cheap, I had a german ask me 600euro for a s/h one, and I had Paul E ask me about £160 for a s/h one no warranty. I gave £80 and will take £80. P.M. me if you want it. Good price there grab it if you can Quote Link to comment Share on other sites More sharing options...
tango Posted January 2, 2007 Share Posted January 2, 2007 I think I still have that pump in my garage, £80 plus post. I think thats cheap, I had a german ask me 600euro for a s/h one, and I had Paul E ask me about £160 for a s/h one no warranty. I gave £80 and will take £80. P.M. me if you want it. Hi there, how old is the pump? p&p ? cheers Quote Link to comment Share on other sites More sharing options...
Chiefgroover Posted January 2, 2007 Share Posted January 2, 2007 I bought it s/h so I cant g/tee the age or mileage, but it worked great for me for 6 months. Quote Link to comment Share on other sites More sharing options...
alan_blue Posted May 6, 2007 Share Posted May 6, 2007 did you solve this mate? Quote Link to comment Share on other sites More sharing options...
tango Posted May 6, 2007 Share Posted May 6, 2007 Hi there, I think its sorted for now, what I done was put in a tube of additive, then it run fine after, I may just consider fluid change later. Quote Link to comment Share on other sites More sharing options...
