intercoolers
supraaaaaaaaaa
With a large FMIC there will be a pressure drop that can actually increase lag. Fitting a large 3-4 row FMIC will also block airflow to the radiator badly and you may find your radiator would need replacing as well. If I were fitting an FMIC I'd also make sure I got it properly ducted.
An SMIC in good condition should also be fine for a small single... but there's nothing to stop you fitting an FMIC on stock turbo's.
