Testing 2nd turbo
Polemarch
I have a 1994 Supra GZ and it is all running great. I've not driven a TT before so I have nothing to compare with. The 1st turbo kicks in nice and low and then the power continues more or less consistently up through the curve. Should there be a noticable kick or something when 2nd turbo kicks in or should it be seamless?
Is there a simple test to make sure all is well?
Thanks
Thanks
hi mate there should be a serious kick when turbo 2 comes in,its like all hell braking loose:d
have a look in the FAQ section and there should be some excellent info on how to fault find probs with the sequential system.
once turbo 2 is working you will have a big grin on your face bud!:)
I thought it was all linear unless you had gone BPU at which point (as Rich so eloquently put it) All hell breaks loose.
Unless you have Exhaust mods, a Cat out and increased fuelling AFAIK it sounds to be as expected.
Mike
I agree with this. I have driven a stock UK and Stock J spec recently. The power feels linear.
