Bob Posted September 19, 2006 Share Posted September 19, 2006 What would people recommend for clean, accurate cuts in carbon fibre roughly 1.5mm - 2mm thick? I bought a cheap CF coil pack cover from ebay - 1st one turned up mangled, 2nd one is okay(ish) but doesn't fit at the front as the CF is 'buckled' in. I was going to cut the front bit away so you can see the cam pulleys Link to comment Share on other sites More sharing options...
Guest mk47 Posted September 19, 2006 Share Posted September 19, 2006 im not too sure Link to comment Share on other sites More sharing options...
Bob Posted September 19, 2006 Author Share Posted September 19, 2006 im not too sure lol, cheers dude! Neither am I! Link to comment Share on other sites More sharing options...
colsoop Posted September 19, 2006 Share Posted September 19, 2006 A sharp stanley Knife should do it. Link to comment Share on other sites More sharing options...
uk-rich Posted September 19, 2006 Share Posted September 19, 2006 its a real bastard to cut, i had to use tin snips. but you will struggle to get a "perfect finish" on the cut Link to comment Share on other sites More sharing options...
Bob Posted September 19, 2006 Author Share Posted September 19, 2006 Hmmm, I wonder if it's worth investing in one of those 'roto-zip' type things? Link to comment Share on other sites More sharing options...
Kranz Posted September 19, 2006 Share Posted September 19, 2006 Dremel will do it with a ceramic edged cutting blade such as aluminium oxide. Will cut it nice & clean too. You can get these Dremel type tools (cheap versions) most places for about £20 or less, including at Agros. Link to comment Share on other sites More sharing options...
uk-rich Posted September 19, 2006 Share Posted September 19, 2006 i tried a dremmel, but with the serated steel blade, it lasted about 5 seconds ! Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 19, 2006 Share Posted September 19, 2006 You need a diamond cut off wheel in an air die grinder. Not as expensive / exotic as it sounds, cheap cut off wheels are OK for the amount of work involved in your project. Rotational speed is what you need. Link to comment Share on other sites More sharing options...
supRo Posted September 19, 2006 Share Posted September 19, 2006 Is it the Pre-preg/Gelled stuff or the non gelled CF? I bought CF in a roll, non gelled and used a Stanley Knife. There's a member on here who works with CF for a living. Can't remember his user name but he worked on the new world record holding fastest Diesel vehicle, powered by twin JCB engines. Do a search and PM him Link to comment Share on other sites More sharing options...
