Metal Polishing Kit Question
SupraAyf
Hi guys,
Just a quick one but over the last few months, I have polished a few things under my bonnet and I have attained some real good results. The problem is that is takes so bloody long with the basic materials that I have been using (An example of my work is in my 'well-outdated' garage pics where you can see my HKS intake is looking fairy OK).
The question is: Do any of you know where I can get a kit that grinds down the metal and then buffs it also (or at least where I can get the different component parts). It will clearly take a couple of stages to achieve but does anyone know where I could get such a kit (and at what cost). The DIY stores seem to have bugger-all.:search:
Cheers for you help in advance,
Andrew
This is the one I got of e-bay same as the one Jamie p has I believe 2, very impressed with it :D
http://cgi.ebay.co.uk/12-pc-Polishing-Kit-for-Brass-Copper-Iron-Steel-Alloy_W0QQitemZ180026424441QQihZ008QQcategoryZ25644QQtcZphotoQQcmdZViewItem
If you have a look in there eBay shop they do loads of stuff
You need to get it smoothed out with at least 300-400 grit paper and then you can use this for the polishing :D
Well, i will be picking up more materials tomorrow so if you want anything please let me know tonight.
I warn you though polishing is a dirty slow and laborious job. I look like a coal miner at the end of a days work. :D
I second that, iv only done a few bits and it's so laborious takes hours! but i think the results are very rewarding :D
http://img179.imageshack.us/img179/3461/16092006aj0.jpg
This is the intake pipe from my HKS induction kit (yes i know it's going to kill my engine) started of as just a rough casting with dimples all over it. :D
