lucasl Posted September 6, 2006 Share Posted September 6, 2006 yea ive got a 112mph delimiter and speedo convertor installed, i was wondering if it still has a 155mph limiter on the j spec models its a manual if that makes any difference. lol not that i need to go these speeds i just wanna be in control of my engine If i remove the trac fuse anyway to get rid of the traction control the slip light would stay on right, so would removing the bulb solve this? Link to comment Share on other sites More sharing options...
BASHTHEBISHOP Posted September 6, 2006 Share Posted September 6, 2006 Definitely not limited to 155:) Link to comment Share on other sites More sharing options...
Bob Posted September 6, 2006 Share Posted September 6, 2006 If i remove the trac fuse anyway to get rid of the traction control the slip light would stay on right, so would removing the bulb solve this? I've always found that removing a bulb is a sure-fire way of turning off a light Link to comment Share on other sites More sharing options...
JohnA Posted September 7, 2006 Share Posted September 7, 2006 The freakin UKSpec is limited to 155. You have to pull the TRAC fuse to see over 165 on the speedo, but on an auto this is not a good idea. On this respect:= JSpec - UKSpec: 1-0 Link to comment Share on other sites More sharing options...
Ian C Posted September 7, 2006 Share Posted September 7, 2006 Some delimiting methods change the limiter from 180kph to 180mph ( ), but that's about it. -Ian Link to comment Share on other sites More sharing options...
lucasl Posted September 7, 2006 Author Share Posted September 7, 2006 ok ive allready installed a trl speedo convertor and top speed delimiter, i was wondering tho as on the uk and us models if it still has a 155mph limiter on it Link to comment Share on other sites More sharing options...
Keith C Posted September 7, 2006 Share Posted September 7, 2006 The freakin UKSpec is limited to 155. You have to pull the TRAC fuse to see over 165 on the speedo, but on an auto this is not a good idea. On this respect:= JSpec - UKSpec: 1-0 But if you *don't* have an auto, then it's a completely FOC way of removing the limiter Link to comment Share on other sites More sharing options...
smithy23 Posted September 7, 2006 Share Posted September 7, 2006 ive a uk spec manual, soif i remove the trac fuse ill remove the limiter? what does the trac fuse do? Link to comment Share on other sites More sharing options...
JohnA Posted September 7, 2006 Share Posted September 7, 2006 ive a uk spec manual,...what does the trac fuse do? It applies the brakes (among others) when you hit the loud pedal. Seriously. On a manual I would perhaps consider crippling it (or disengaging it often) On the auto it also fiddles with the stupid flap and ignition retard to soften the blow during gearchanges, so pulling the fuse isn't really a good idea. Link to comment Share on other sites More sharing options...
lucasl Posted September 8, 2006 Author Share Posted September 8, 2006 The trac fuse is to do with the traction control, just pushing the 'trac off' button only partially disables the trac system. It disables the trac throttle body and trac function throught the abs system on 93,5-96 only, but not the trac system ignition timing retard function. Unplugging the trac fuse eliminates both fuctions as well as the 155mph limiter which im trying to figure out if ive got this on my j-spec. If the trac fuse is removed the trac light will stay on though. Link to comment Share on other sites More sharing options...
lucasl Posted September 8, 2006 Author Share Posted September 8, 2006 the 155mph speed limiter works through the trac throttle body, unlike the j-spec 112mph limiter which is in the ecu Link to comment Share on other sites More sharing options...
