Tourniquet Posted September 3, 2006 Share Posted September 3, 2006 Right lads n ladettes I've broke me beast. From a look under it today I need the following if anyone knows of cheap bits, reccomended bits or bits you're selling yourselves. 1) Rear shock - pair'd be better obviously but only 1's leaking at present. 2)Wheel bearing kit (again one gone but may as well do the 2) 3) Rear pads n discs (any ones u reccomend in particular - even stock) 4) Bottom T.C.A arm bush 5) Zaust (want to blow me house down with it - Drager or Nurspec) It's got a shark bite type hole on top of the pipe right behind the can. 6) Ooh and traction bar (small thing with 2 ball joints on) Obviously bearing kits and such aren't much to choose from but brake discs n zausts I'd appreciate the advice and if any of you have twatted your Supe and are stripping it I could do with some odds n sods. If it matters it's a '94 L plate J-spec twin turbo. Cheers people. Quote Link to comment Share on other sites More sharing options...
Nic Posted September 4, 2006 Share Posted September 4, 2006 Sorry to hear that How urgently do you need the parts? I should be able to save you a lot of cash on new OEM parts, but order time would be 4-5 weeks. Quote Link to comment Share on other sites More sharing options...
Heyrick Posted September 4, 2006 Share Posted September 4, 2006 Hi, I've got one spare stock rear shock absorber. Just replaced my rears with bilsteins (from nic) as I already had them on the front and one of my rears started leaking. Looks to be in good condition, with no leaks and works ok etc. Not sure what it's worth but make me an offer if you're interested. Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted September 4, 2006 Share Posted September 4, 2006 hi mate reccomend changing both shocks even though only 1 is messed.. and as for exhaust id reccomend the new miami gt one, check out the sound clip of mine and moist fingers somewhere in supra chat. good luck hope you get it all sorted. Quote Link to comment Share on other sites More sharing options...
Tourniquet Posted September 7, 2006 Author Share Posted September 7, 2006 Is there much difference in price for stock and Koni adjustables or is another make better ? Also do wheel bearings need to be pressed by machine for the Supra's ? Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted September 7, 2006 Share Posted September 7, 2006 get Mr.T to press the wheel bearings... i was chatting to RobSheffield the other week and this is what he did ... hope you get it back up and running soon Quote Link to comment Share on other sites More sharing options...
Ian W Posted September 7, 2006 Share Posted September 7, 2006 Is there much difference in price for stock and Koni adjustables or is another make better ? Also do wheel bearings need to be pressed by machine for the Supra's ? if you can, go for the jap stock yellow bilsteins Quote Link to comment Share on other sites More sharing options...
JODY T Posted September 7, 2006 Share Posted September 7, 2006 Ive got a set (4) of clean Yellow Billies from a low miler, Pm if you are interested... (By the way these are mine not MKivstore) Quote Link to comment Share on other sites More sharing options...
Ian W Posted September 7, 2006 Share Posted September 7, 2006 Ive got a set (4) of clean Yellow Billies from a low miler, Pm if you are interested... (By the way these are mine not MKivstore) duuuuuude! Quote Link to comment Share on other sites More sharing options...
