Adam Posted August 25, 2006 Share Posted August 25, 2006 As it says. The brake fluid is full and i dont have an active spoiler. it doesn`t come on till i hit 80. Once it comes on it stays on till i turn the engine off. The car doesn`t feel like there is anything wrong. Can anyone help Link to comment Share on other sites More sharing options...
Daston Posted August 25, 2006 Share Posted August 25, 2006 Sorry dude cant help ya but if you ask a mod to move this to the tech section you will more than likely get a better answer Link to comment Share on other sites More sharing options...
Class One Posted August 25, 2006 Share Posted August 25, 2006 I'll leave it in chat for now. Try here for a guide as to how to find your fault code. When you've done that, then it might be easier to diagnose your fault. Link to comment Share on other sites More sharing options...
Dave Posted August 25, 2006 Share Posted August 25, 2006 does there triangle come on as well check your fault codes you will then find out what can be done same thing happened to mine Link to comment Share on other sites More sharing options...
Adam Posted August 25, 2006 Author Share Posted August 25, 2006 yeah it does. will check them. Its got me stumped thats for sure. Link to comment Share on other sites More sharing options...
Matt Harwood Posted August 25, 2006 Share Posted August 25, 2006 Adam, if you're not sure about checking your fault codes, you're welcome to pop it over to me and I'll show you how. It's most likely a speed converter issue. Code 42 Link to comment Share on other sites More sharing options...
penguin Posted August 25, 2006 Share Posted August 25, 2006 most likely a speed sensor *sorry matt didnt see your reply* Link to comment Share on other sites More sharing options...
Adam Posted August 26, 2006 Author Share Posted August 26, 2006 Cheers matt. R u about today at all. Im in maidstone this morning Link to comment Share on other sites More sharing options...
Matt Harwood Posted August 26, 2006 Share Posted August 26, 2006 Yes mate Link to comment Share on other sites More sharing options...
Adam Posted August 26, 2006 Author Share Posted August 26, 2006 Sweet. i will pop over about 10 ish if thats ok Link to comment Share on other sites More sharing options...
Matt Harwood Posted August 26, 2006 Share Posted August 26, 2006 That's OK. See you then. Link to comment Share on other sites More sharing options...
Nic Posted August 26, 2006 Share Posted August 26, 2006 Do you have an auto front spoiler and/or the buttons for it under the stereo? My guess is the warning light is for the auto spoiler (either been removed or not deploying). To test if it is this try pressing off button and see if you get the warning light coming on still. Link to comment Share on other sites More sharing options...
supragold Posted August 26, 2006 Share Posted August 26, 2006 Its warning you that your reaching 88 miles an hour and will go back in time LOL Link to comment Share on other sites More sharing options...
Dave Henshall Posted August 26, 2006 Share Posted August 26, 2006 1.21 gigawats Link to comment Share on other sites More sharing options...
lockys96 Posted August 26, 2006 Share Posted August 26, 2006 i had this when i first got mine, however mine did it between 65-70mph. it was the spoiler ecu thinking it would cut in, when i dont have the active spoiler fitted, simply disconected the spoiler ecu and it was fixed, could be this Link to comment Share on other sites More sharing options...
imi Posted August 26, 2006 Share Posted August 26, 2006 ive got a similar problem with mine. If I disable the spoiler ECU then am I correct to presume that I wont be able to lower my spoiler (in manual mode) anymore....or is the ECU only for the automatic speed dependant deployment. Link to comment Share on other sites More sharing options...
Matt Harwood Posted August 26, 2006 Share Posted August 26, 2006 i dont have an active spoiler. Link to comment Share on other sites More sharing options...
DamanC Posted August 26, 2006 Share Posted August 26, 2006 Mine does it at 90 leptons, error 42, ill get round to sorting it one day...... Link to comment Share on other sites More sharing options...
Adam Posted August 26, 2006 Author Share Posted August 26, 2006 Gonna do mine tommoz thanks to matt:thumbs: . Cheers mate. Will have a go at disconnecting the rsm. Link to comment Share on other sites More sharing options...
