jaymdee Posted August 18, 2006 Share Posted August 18, 2006 Why is it a simple thing creates more problems!!! I've noticed a water sloshing noise from the back of my car recently, and have concluded that my TRD wing is letting water into the side pods. So I took it off today, emptied the water out and placed plastic cement/sealant where there are gaps where the bolt holes go. Start to put it back together and drop one of the bastard bolts down into the rear hatch and it slides up between the outer and inner skins no chance of getting it out with fingers). So I'm now gonna have the sound of a bolt rolling back and forth in the hatch every time I accelerate, brake and go round corners. I can hear it sliding when I open & close the hatch. Anyone else done this (and going to admit to it!) and got any tips for getting the bleeder out???? J Link to comment Share on other sites More sharing options...
Pete Posted August 18, 2006 Share Posted August 18, 2006 Powerful magnet? Link to comment Share on other sites More sharing options...
Guest mk47 Posted August 18, 2006 Share Posted August 18, 2006 try one of those aerial looking things that some garages use to pull spark plugs out with. they have a very strong magnet and very thin so can get through gaps. Link to comment Share on other sites More sharing options...
jaymdee Posted August 18, 2006 Author Share Posted August 18, 2006 try one of those aerial looking things that some garages use to pull spark plugs out with. they have a very strong magnet and very thin so can get through gaps. Sounds like the fella I need. Probably find the damn things not magnetic Link to comment Share on other sites More sharing options...
colsoop Posted August 18, 2006 Share Posted August 18, 2006 Can't you take the plastic cover off the tailgate, you should be able to reach it easier then. Link to comment Share on other sites More sharing options...
Nic Posted August 18, 2006 Share Posted August 18, 2006 I've done this before, luckily was able to reach it just. If you close the boot will it slide down to the end so you can reach it? Link to comment Share on other sites More sharing options...
GazzaGSi Posted August 18, 2006 Share Posted August 18, 2006 I did this when fitting mine acouple of weeks back, fortunately i could see it and poked it with a screw driver and got my fingertips on it. As regards the water problem. Did you have 2 sticky pads which stick to the face of the spoiler which meets the tailgate when bolted to it? Or was the spoiler touching the boot with no pad? Gaz Link to comment Share on other sites More sharing options...
jaymdee Posted August 19, 2006 Author Share Posted August 19, 2006 I've done this before, luckily was able to reach it just. If you close the boot will it slide down to the end so you can reach it? Hi Nic, No I can't reach it, but I drove the car last night and it moved down to the bottom near the plastic bit, so I'm going to check in a minute. Have also ordered an extendible magnet from Ebay for £3.50 As regards the water problem. Did you have 2 sticky pads which stick to the face of the spoiler which meets the tailgate when bolted to it? Or was the spoiler touching the boot with no pad? Gaz Gaz, yes I bought the sticky pads for the underside of the side parts of the spoiler where it touches the boot, but the water's come in from the top where the centre piece bolts to the side pieces. Hope fully all sealed now J Link to comment Share on other sites More sharing options...
Soop Dogg Posted August 19, 2006 Share Posted August 19, 2006 I have a couple of those telescopic magnet things. It's a bit of a standing joke with IanC and myself - I had to find the most powerful one I could, so when on a weekend in Derbyshire, I found one in a little hardware store for 99p - it is capable of lifting (wait for it) 8lb!!! Trouble is, if the lost nut/bolt is lying amongst other magnetic metals, you've no chance of getting this thing near it as it alwars twangs off in the direction of the nearest bit of metal and attaches itself to it! (Sorry - not relevant I know but had to share that with you all) Link to comment Share on other sites More sharing options...
Daston Posted August 19, 2006 Share Posted August 19, 2006 what about one of those long thin claw's? Link to comment Share on other sites More sharing options...
jaymdee Posted August 19, 2006 Author Share Posted August 19, 2006 8lb I've been had then This one will only lift 2lb, (but it is quite small.) 99p for 8lb = 12.375 p/lb 3.50 for 2lb = 175 p/lb Daston, may have worked, but can't see it. Have ordered magnet now mate, hopefully sort it in the week J Link to comment Share on other sites More sharing options...
