What intercooler fits without removing the active spoiler?
Andrew
I know you can get the active spoiler to stay down when you fit front mounted intercoolers, but I'd like mine to be active if possible.
There is a Greddy intercooler that fits in the stock postion, are these anygood? Would adding a water injector to it, give similar effects as a large intercooler?
It sounds as if you need my uprated, all aluminium, latest type core, stock mount IC. No mods needed to the active spoiler, everything works normally. Add WI if you like, it can only help. I also do WI kits at an excellent price. E-mail me direct if you want more info, see my sig below.
Originally posted by NWS25
Water Injection.
Of course! Doh. Thanks
I've never liked the sound of Water Injection myself, I'm sure it's sound enough really but it just sounds wrong to me.
[/ludite]
Originally posted by Jake
:clueless: WI ? :conf:
Water Injection, info from an article I wrote below:
Water injection serves 2 closely related functions on a turbo engined
car. Firstly it cools the charge air temperature by utilising an effect
known as the latent heat of evaporation. This property can be self
demonstrated very easily. If you pour something that evaporates quickly
like petrol on your hand it feels very cold. This is the rapidly
vaporising spirit removing heat from your skin and bloodstream by the
aforementioned process. By spraying a very finely atomised mist of water
into the inlet of a turbo engine when under boost conditions the
evaporation of the water into steam causes a temperature reduction in the air and
fuel intake charge. A cold charge is less likely to be subject to
detonation than a hot charge. A cool charge is also denser, able to
carry more air and fuel mix per unit of volume. These 2 properties of
water injection allow either less chance of detonation at a given boost,
maybe allowing lower octane fuel to be used, or to allow a rise in boost
pressure usage without detonation. These are very desirable goals for
any modifier of a turbo engine, or one using an engine mapped to run
on a higher octane fuel than generally available in the UK. Japanese
import turbo cars for example.
People ask whether squirting water into an engine causes corrosion. In
fact this is not a problem, the combustion temperatures under boost
ensure the water is turned instantly to steam and is ejected out of the
exhaust. The water mist is injected only when high boost is sensed via
a supplied pressure sensor switch. The basic combustion process of
hydrocarbon fuels causes LOTS of water to be generated anyway, which is why cars
not driven on regular long journeys will rust out a mild steel exhaust
system from the INSIDE out. If water is added in the correct volume, via
the supplied, calibrated jets, this is not a problem.
Even when used alongside a larger or more efficient intercooler, or
indeed when an intercooler is used in an application where one was not
present as standard, water injection can and does increase charge cooling
still further. Water can be stored either in the existing windscreen
washer bottle or in a separate, dedicated, container. In cold conditions
it is essential to add an anti freeze additive to the water to stop pump
damage through freezing. Windscreen washer additive serves this purpose
fine and the engine won't mind ingesting this solution at all. Or you
can add neat methanol, which is usually the anti freeze additive in
washer fluid anyway. Using a 50 / 50 percent by volume water / methanol
mix will actually help increase the octane of the intake charge, as an
added benefit. As a yet further advantage the latent heat of evaporation
of methanol is extremely high. A win / win situation. It is not however
obligatory to use methanol as an additive. All components of the water
injection kit that are in contact with the fluid are stainless steel or
able to tolerate water and methanol or screen washer additive without
degradation. A properly set up system does not use a vast amount of
water, in fact a modern car sized screen washer bottle used also for the
water injection reservoir will suffice admirably. A water filter is
included to keep any sludge out of the pump or jet. This should be
checked regularly for contamination and blown out if residue is
apparent within.
That was quick, thanks :)
I'm in favour of your SMICs Chris, as ripping out a £2000 spoiler seems a bit silly to me ;)
I only ever plan to run 1.2 bar anyway.
Does anyone know how good the stock intercooler is, i.e performance parts quote bhp figures, the HKS S type is good for 500bhp etc. What would the stock intercooler be good for?
Or am I barking up the wrong tree :stupid:
Hello Chris,
The article says that your kits is ok with methonal as well as water so I am guessing that you do not use the ERL Aquamist kit then, could I use my AEM as the controller for your kit and where is the best place to buy methanol?
:thumbs:
On another note, the rest of my turbo kit is now in the country :D
Originally posted by Wez
Hello Chris,
:thumbs:
The ERL kit is the one I recommend as it uses a purpose made pump with adequate pressure AND flow, something most competitors fail to achieve. It's fine with methanol / water mix through it, it even states this on the box.
It should be fine with pure methanol, but i wouldn't recommend it, it makes too big a difference to the air / fuel ratio. It would be OK on a fully mapped system with the engine ecu "clever" enough to also refuel to suit when the WI was running, too. Far too complex for a road car.
I was looking at the ERL System 2c to maybe do exactly that using the AEM nitrous and a spare PWM control. The AEM has the ability to switch to a modified ignition and fuel map at the flick of switch, this switch would also turn on the water / methanol or just methonal injection and also raise the boost target.
The ERL System 2c also has a signal wire that could be wired to the AEM to revert back to normal boost and maps if there was a pressure drop or blockage etc.
http://www.aquamist.co.uk/cp/sys2c/sys2c.html
Would the gains not be worth the hassle?
