Guest giama Posted August 13, 2006 Share Posted August 13, 2006 has anyone installed booslogic's NA-T kit on their RHD UK supra, if so, was any modifying required to clear steering column?, was the kit a straight fit, what problems/re-fabricating was required? if anyone has any links to threads were this kit was installed id appreciate it, i searched and couldnt find. thanks Link to comment Share on other sites More sharing options...
SatSport Posted August 13, 2006 Share Posted August 13, 2006 think `Bromy` on here had one done by Thor was it?? Link to comment Share on other sites More sharing options...
bromy Posted August 13, 2006 Share Posted August 13, 2006 Phoenix in watford fitted my kit give Mark a ring there and ask him 01923 228484 Link to comment Share on other sites More sharing options...
Guest giama Posted August 13, 2006 Share Posted August 13, 2006 hey bromy, is it ok if you posted some pics of your engine bay from different angles?, also im from australia. in your pm u said their was some fitting issue, do the 525cc injectors fit the stock na fuel rail?, does the wastegate and exhaust downpipe clear the steering column? you said things needed modyfing, but what was it exactly, cheers mate. Link to comment Share on other sites More sharing options...
Jackal Posted August 13, 2006 Share Posted August 13, 2006 Phoenix in watford fitted my kit give Mark a ring there and ask him 01923 228484 Is that place next to Sapphire coachworks, off St Albans Road? Link to comment Share on other sites More sharing options...
Matt Harwood Posted August 13, 2006 Share Posted August 13, 2006 Is that place next to Sapphire coachworks, off St Albans Road? Sounds about right Link to comment Share on other sites More sharing options...
bromy Posted August 13, 2006 Share Posted August 13, 2006 Pretty sure it had something to do with the steering column you will need to ask Phoenix to be sure as you say most are fitted to lhd cars Link to comment Share on other sites More sharing options...
Guest giama Posted August 14, 2006 Share Posted August 14, 2006 u got any pics of yours bromy, links etc of pics of your cAR? Link to comment Share on other sites More sharing options...
bromy Posted August 14, 2006 Share Posted August 14, 2006 T61 Fuel rail Fuel pressure regulator E-manage Boost controller Link to comment Share on other sites More sharing options...
squiffy Posted August 14, 2006 Share Posted August 14, 2006 very tidy mate, may be looking into this in the future, what power you putting out and what was the cost if you dont mind me asking? Link to comment Share on other sites More sharing options...
SatSport Posted August 14, 2006 Share Posted August 14, 2006 nice install, what`s the injectors? Any power figures? Link to comment Share on other sites More sharing options...
Guest p_streaks Posted August 10, 2008 Share Posted August 10, 2008 NICE!! lil bump from the pass..but what power figures are you getting? I just ordered the same kit but with 780CC injectors. Hope to get close to 500rwhp in the end.. Link to comment Share on other sites More sharing options...
Lebsteif Posted August 10, 2008 Share Posted August 10, 2008 Keep in mind that your stock 5spd gearbox won;t hold 500rwhp, also you need to modify the intercoolerpipework because of the steering column. Link to comment Share on other sites More sharing options...
couv3z Posted August 10, 2008 Share Posted August 10, 2008 Keep in mind that your stock 5spd gearbox won;t hold 500rwhp, also you need to modify the intercoolerpipework because of the steering column. ?? Link to comment Share on other sites More sharing options...
JamieP Posted August 10, 2008 Share Posted August 10, 2008 ?? What part are you questioning? Fact 5 speed box is not very strong and will not hold that sort of power and i presume the ic pipe that comes off the turbo can foul the steering column on rhd cars. Link to comment Share on other sites More sharing options...
couv3z Posted August 10, 2008 Share Posted August 10, 2008 What part are you questioning? Fact 5 speed box is not very strong and will not hold that sort of power and i presume the ic pipe that comes off the turbo can foul the steering column on rhd cars. sorry my reply wasn't very accurate the 5 speed box is what i'm questioning i assume its not the same as the TT 5 speed then? Link to comment Share on other sites More sharing options...
JamieP Posted August 10, 2008 Share Posted August 10, 2008 sorry my reply wasn't very accurate the 5 speed box is what i'm questioning i assume its not the same as the TT 5 speed then? No such thing as a TT 5 speed box, the TT box is a very strong 6 speed Getrag unit. Link to comment Share on other sites More sharing options...
couv3z Posted August 10, 2008 Share Posted August 10, 2008 oh dear... so *if* i was ever to take my na-TT to above 500bhp i'd need a 6 speed lump Link to comment Share on other sites More sharing options...
JamieP Posted August 10, 2008 Share Posted August 10, 2008 IMO yes over 500bhp you would need a 6 speed box. Link to comment Share on other sites More sharing options...
Guest p_streaks Posted August 10, 2008 Share Posted August 10, 2008 A have a 6-speed SZ-R =] Just waiting on kit now. Dont know if ill need to do cams though to push it to 500 on that t61? Link to comment Share on other sites More sharing options...
Lebsteif Posted August 11, 2008 Share Posted August 11, 2008 IMO yes over 500bhp you would need a 6 speed box. Or swap it for a R154 (MKIII turbo gearbox) Link to comment Share on other sites More sharing options...
Golddigga Posted August 11, 2008 Share Posted August 11, 2008 Is this gearbox really a go'er? How strong is this? I am really tempted to go N/A-T but so far have been a bit put off by the fact that I have been told that to do it right would cost £7-10k?? Any views appreciated Point of note - I know where the search button is thanks, just wondered if there are any new views - new projects that have gone N/A-T? Link to comment Share on other sites More sharing options...
Guest p_streaks Posted August 11, 2008 Share Posted August 11, 2008 Or swap it for a R154 (MKIII turbo gearbox) oH I see you have the BL kit too! What kinda power figures are you pulling mate? And how does it feel!! Link to comment Share on other sites More sharing options...
