Extending the battery cables
snoot
  • 1 year later...
Personally, I'd suggest the easiest way without spending a fortune on mahoooosive soldering irons, I would recommend using 4awg cable as a minimum, and use the correct size ring terminals. Then nut & bolt the ring terminals together and insulate the connection, cable tieing it to something sturdy.
You can get a proper soldering iron for soldering massive cables, but they cost about £100+
Alternatively, neater and better, but more expensive, replace the cable to the starter motor and the fuse box completely. The cables bolt on to the starter and fusebox. Same with the earth cables.
Good luck!
