SUPRALOOPY Posted July 4, 2006 Share Posted July 4, 2006 Is this alot to worrie about? or can this wait until i've saved enough for some new turbos? Don't want to do too much damage if i can help it;) I dont lose any oil and i don't get smoke when on boost driving. SEE_HERE Also my boost is peaking at 1.08 kg/cm2 (can some one convert that for me ) Many thanks Dave:) Link to comment Share on other sites More sharing options...
hadyn Posted July 4, 2006 Share Posted July 4, 2006 That could be bad valve stem seals mate if that huge puff came out just after switching the engine on after leaving it over night. Turbo seals, usually puff out the smoke when on boost Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted July 4, 2006 Author Share Posted July 4, 2006 nothing on boost? thats whats getting me.. that was after a good drive and its getting better. going to look into the pcv or psv valve as i heard they get shitted up and smoke? but i don't really know on this one. Link to comment Share on other sites More sharing options...
kamikaze Posted July 5, 2006 Share Posted July 5, 2006 This may help but may not... Your symptoms sound similar to clogged PCV valves hoses that i had on my 300ZX-If the Supra has a similar system it could be these I replaced mine resulting in no more sooty marks on the exhaust/increase in power at low revs/no smoke from exhausts Hope that helps Link to comment Share on other sites More sharing options...
Swampy442 Posted July 5, 2006 Share Posted July 5, 2006 Your turbos would smoke when its at idle and warm, they dont tend to do it cold. Looks like the PCV to me too Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted July 5, 2006 Author Share Posted July 5, 2006 how do you get the pcv out?? ive cleaned the tube (bastard to get back on) and sprayed carb cleaner down the valve, but how do you check it? can't find anything in cj's manuals. Link to comment Share on other sites More sharing options...
Swampy442 Posted July 5, 2006 Share Posted July 5, 2006 Its an NRV so I guess if its stuck then it wont relieve any pressure. If its freely moving about then I assume it works ok. You can get a new one if in any doubt though, cant be that much. Link to comment Share on other sites More sharing options...
chris aka fonz Posted July 5, 2006 Share Posted July 5, 2006 This may help but may not... Your symptoms sound similar to clogged PCV valves hoses that i had on my 300ZX-If the Supra has a similar system it could be these I replaced mine resulting in no more sooty marks on the exhaust/increase in power at low revs/no smoke from exhausts Hope that helps PCV valves ? Sorry bit dumb when it comes to these things ! Somebody tell me what these do and where situated please Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted July 5, 2006 Author Share Posted July 5, 2006 PCV valves ? Sorry bit dumb when it comes to these things ! Somebody tell me what these do and where situated please A little valve type thingy on the n/s cam cover going to the intake plenum. Its got an s type pipe connecting the two. (or i've fooked something else then:( ) Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted July 5, 2006 Author Share Posted July 5, 2006 Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted July 5, 2006 Author Share Posted July 5, 2006 But not as bad? I will take ot out again soon and see if its getting better? Link to comment Share on other sites More sharing options...
kamikaze Posted July 6, 2006 Share Posted July 6, 2006 PCV valves ? Sorry bit dumb when it comes to these things ! Somebody tell me what these do and where situated please Depends if you mean on a 300ZX or a MKIV lol On the 300ZX you have one on each side under the plenum towards the rear of the engine... There are also a total of 5 hoses in the system that need to be replaced as well as they have small 'brushes' inside em to clean and filter. Ive got no idea on a MKIV as i havent got one yet!Well til Sunday anyway. Link to comment Share on other sites More sharing options...
