Uneven Tyre Wear + Spacers
SupraSapphire
I could do with some expert opinions on my wheel + tyre setup. The front tyres are wearing very unevenly (See attatched pic). I've just had all 4 tyres replaced and don't want the same thing happening to the new front tyres. As you can see from the pic the old tyres are completely bald on the inside edge but have loads of tread left on the rest of the tyre.
So my first question is - is it the spacers that are causing the uneven wear? I've currently got 25mm bolt on spacers. The wheels are 8.5 wide and have an offset of 40mm. So this means that the total offset is 65mm, which is 15mm over the standard offset, I think :conf:
The second question is - if it is the spacers should I change them for smaller 10mm spacers, that will just about do the job but won't be the safer bolt on type and will involve fitting longer studs? Or is it posible to alter the geometry setup to compensate for the extra offset?
mine did the same but much worse, get a good 4 wheel lazer alighnment done, if you can travel over here (not far from wheel mania where you got the alloys from) i know an excelent place that did mine very cheap, DO NOT TAKE IT TO CHEMEX !! they charged me over a ton and buggered every thing up then told me tough !!
'Wheel Mania' :eek: just hearing the name angers me :angry: Bunch of monkeys! But we won't go into that.
Did the wheel alignment fix your problem? I had mine done by CW while he was servicing it just after having the wheels fitted. That reminds me, I've got a service due in March. I'll have to book it in with Chris :)
I noticed with my old standard wheels that the inside edge was slightly more worn than the rest. But like you say Tim "not like that"
yes my tyres now wear right the way accross evenly 100%, and i have just gone through a full set of tyres, they were even all the way through there life.
if CW has done it i cant see it being that as i know he does an excelent job, the machine by me (so i have been told) takes into acount your rim size and sets the correct setting to compensate to factory settings, only 1 of 2 in the country (again only what i have been told) but i do know ALL the cars i have heard about from there have had bang on tyre wear, even a corsa with 19's !
Just had all my alignment done. Apparently youre supposed to get this done before you change your tyres because it will have the same effect on the new ones. Thtas what i was told, so got the alignment done and am now looking for new tyres. Prob going for Falkens.
