mikeyb10supra Posted June 29, 2006 Share Posted June 29, 2006 Has anyone done this and do they have instructions on how to remove? Ta Mikey:) Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted June 29, 2006 Share Posted June 29, 2006 undo the two bolts that hold it to the down pipe and unplug it from the loom. Link to comment Share on other sites More sharing options...
mikeyb10supra Posted June 29, 2006 Author Share Posted June 29, 2006 sounds easy enough....is it trickt to get too? Link to comment Share on other sites More sharing options...
Getrag Posted June 29, 2006 Share Posted June 29, 2006 In not even a techie and I could take it out. Drivers side of the engine bay...exhaust manifold...downpipe...02 sensor sticking out the side. Link to comment Share on other sites More sharing options...
Lucifer Posted June 29, 2006 Share Posted June 29, 2006 Nope its that easy. Just dont Sheer the 2 M10 bolts off Link to comment Share on other sites More sharing options...
Daston Posted June 29, 2006 Share Posted June 29, 2006 isnt there 2 sensors? Link to comment Share on other sites More sharing options...
jamesmark Posted June 29, 2006 Share Posted June 29, 2006 isnt there 2 sensors? I think only on UK spec iirc Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted June 29, 2006 Share Posted June 29, 2006 isnt there 2 sensors? No one is a cat temp sensor. Link to comment Share on other sites More sharing options...
Daston Posted June 29, 2006 Share Posted June 29, 2006 ah so whats the other cable that runs from the front of the car to the down pipe? Just wondering as I will of corse be pulling theres out in a few months when my turbo goes in Link to comment Share on other sites More sharing options...
Lucifer Posted June 29, 2006 Share Posted June 29, 2006 Assuming TT J-SPec ------- 1 X O2 Sensor 1 X Post Cat Termo coupling UK-SPec ------- 1 X O2 Sensor 2 X Post Cat Termo coupling , 1 in 1st and one in 2nd cat. Link to comment Share on other sites More sharing options...
supRo Posted June 29, 2006 Share Posted June 29, 2006 I put this up on Nic's Group buy thread: Just to add, I changed the o2 sensor on my TT and it was one of the best thing I have done to the car as fuel economy improved greatly ! Here's a little guide to help you change it: How to change: Replacing the sensor is very easy. On my Jap pre-VVTI it's located just below the turbo on the downpipe. The sensor comes with the lead attached and a new gasket. New bolts (reccomended) T90179-08059. 79p (2 needed). It may be easier if you take off the first/top Intercooler pipe and air intake pipe off. There are 2 12mm(?) nuts holding it on. Slight pain to get to - bit of soaking in wd40 makes it easier to get them off. There are two push fit studs that clips the lead in place. The one nearest to the turbo is easy to take out - pair of pliers to squeeze the prong. The other one is a bit of a PITA as you can't access the prongs of the studs. You may want to cut out/drill the stud if you want to re-use the hole. Or cut the plastic top bit to release the cable. The end of this cable is push fit fitting which attaches to the lead that goes to the ECU directly I think (??). Just disconnect this, near the actuator/fan area. To fit the new sensor, just reverse the process. It's probably worth re-setting the ECU after this (Pull out the two Green 30 Amp EFI fuses for 30 seconds) Ro Link to comment Share on other sites More sharing options...
MKIVDreamer Posted June 29, 2006 Share Posted June 29, 2006 Just to add some minor detail to the excellent info above. it IS a 12mm socket - You may find you need a deep socket if like me you have an el-cheapo socket set. Make sure you get the old gasket off, I ended up easing it off with a flat bladeed screwdriver, but be very careful that you don't score the face under the gasket! My gasket was very old/worn and left some material on the down pipe, I used a damp soft scourer to remove it. HTH Link to comment Share on other sites More sharing options...
Nic Posted June 30, 2006 Share Posted June 30, 2006 Assuming TT J-SPec ------- 1 X O2 Sensor 1 X Post Cat Termo coupling UK-SPec ------- 1 X O2 Sensor 2 X Post Cat Termo coupling , 1 in 1st and one in 2nd cat. According to the EPC the UK Supra has 2 oxygen sensors; front and rear. The NA Supra also has 2 oxygen sensors. Link to comment Share on other sites More sharing options...
RedM Posted June 30, 2006 Share Posted June 30, 2006 Is there any reson to be taking the 02 sensor out? What would it do? Link to comment Share on other sites More sharing options...
Markie Posted June 30, 2006 Share Posted June 30, 2006 If you are thinking of getting it replaced. Then I would recommend getting a genuine Toyota one. Link to comment Share on other sites More sharing options...
