Cisco guys, got a minute?
carl0s
  • Replies 78
Also, I would suggest, using a third interface either physical or virtual and running the workstations and servers on seperate vlans/subnets.
What's the reasoning here? Packet filtering? Come to think of it, it would be nice to be able to firewall the workstations just in case. When I saw the flood of DCERPC stuff from the IT managers box to the ISA Server, I wondered if it was some wierd worm..
I am assuming you are using a cross over cable between the router and the ISA box... and not running into a switch or something?
I'd hope so, but it was just a mess (about 7 server in the room) and I haven't checked. IT Manager nr2 set that machine up and I haven't heard from them in some time since he started there (I turned down the job.. wanting to keep my freedom.. and poorness.. :D )
I'll be sure to check tomorrow. Good point though :thumbs:
The reason I always seperate workstation and server networks, is so that if f&^kwit user on the network does something weird to his PC he doesn't flood the servers (from a network traffic point of view)...
Also makes debugging things a little eaiser...
What was frustrating was that the bits/sec in the interface counters didn't make sense at all. Whilst downloading at 230KB/sec (over 2,000,000bits/sec), the counter showed about half that.
do you mean these counters :-
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 241000 bits/sec, 207 packets/sec
5 minute output rate 227000 bits/sec, 196 packets/sec
Which are a 5min average so will show a lower rate.
This is a show int from a 3640 I have here.
Yeah but I'd been downloading a 3gb Fedora DVD for over 5 minutes ;)
I was mainly looking at show summary (or was it 'show int sum'). Can't remember if they were 5 min averages or not.
Also, just had another look at the network... How does the ISA box connect to the internet....are we talking another router? an ADSL modem on the box? a cable line? just could add another bit of interesting topology
Ethernet to a 1721 router which backs onto a leased line :D
I know it's more topology but since the problem also shows on non-internet related usage of the 3640 I left that bit out.. it is in effect 'part of the internet' since the public IP comes straight to the ISA box from it.
Physical wiring wise, I would run ALL the links into the switch and have 5 VLANS on the switch
1. Public (unsecure)
2. VPN
3. Servers
4. Workstations
5. Sister company
And then the ISA server has a link into each of those... or and I need some guidance on whether ISA would support it... get two gigabit cards and use VLANing on the server side as well via VLAN trunking..
Sry I havent read the entire thread....so perhaps this has already been mentioned
Setup Vlans on the switch, and a trunk port and hook that to the FA interface on the router (just the one) and do routing on the stick.
mind you it will impact performance, however since you only have a 2Mb link to the internet it shouldnt be a problem.
And something I've completely forgotten about... make sure they know the risk of running the entire core through the ISA box... if it crashes you WON'T have any network at all.... So you might want to get another one and cluster it...
Hmmm, not sure I would route 6 subnet's worth of traffic up and down a single interface... not at 100mbit....purely for performance reasons.... however, with VLANing active it would still be nice and tidy on the switch side... so it is a quick easy option so worth a go
hmm, that was quick. Your pictures are so much sexier than mine.
I see what you're suggesting. I need to google VLAN trunking. Is it bonding two connections to the same VLAN?
My only reservation before on the suggestion of the ISA box doing it all, was that it's publically connected to the 'net, and obviously would become the most vital part of the entire organisation. Is ISA 2004 safe enough?
Personally I don't like ISA since it is based on a microsoft operating system underneath.... I would rather use checkpoint (but it is DAMN expensive) or my personal choice... PIX.... and one of those would do the job nicely.. and you can cluster them...
OK guys, I've taken a lot from this and really appreciate the time you've taken with me.
Priority for tomorrow has to be setting up VLANs where the different subnets are going through the switches, and using the spare interface in the ISA box for the sister company (there's a designated DMZ interface which isn't being used on the ISA box, so hopefully I can do that without having to reboot).
