Justin Posted June 2, 2006 Share Posted June 2, 2006 What temp should I let off the throttle again I have forgotten? This is with stock internals. Was it 950C or lower? Thanks Justin Link to comment Share on other sites More sharing options...
Kopite Posted June 2, 2006 Share Posted June 2, 2006 where's your sensor plumbed J? Link to comment Share on other sites More sharing options...
Justin Posted June 2, 2006 Author Share Posted June 2, 2006 where's your sensor plumbed J? In number 2 on exhaust manifold me finks. Link to comment Share on other sites More sharing options...
Sharpie Posted June 2, 2006 Share Posted June 2, 2006 I'm sure I have seen CW quote upto a max of 950C but, I have my warning set at 900C Link to comment Share on other sites More sharing options...
Pig Posted June 2, 2006 Share Posted June 2, 2006 I have mine set for 850 and thats after the turbo! therefore i would say about 950 would be right! Link to comment Share on other sites More sharing options...
Guest Terry S Posted June 2, 2006 Share Posted June 2, 2006 I found it was approx 200 difference pre/post turbo, so I would say Post turbo 700-750 to be safe. Link to comment Share on other sites More sharing options...
paul mac Posted June 2, 2006 Share Posted June 2, 2006 I found it was approx 200 difference pre/post turbo, so I would say Post turbo 700-750 to be safe. glad you mentioned that Terry i am moving mine from pre turbo to post as i have read to many horror storys, i wondered what the difference was Link to comment Share on other sites More sharing options...
Sharpie Posted June 2, 2006 Share Posted June 2, 2006 I found it was approx 200 difference pre/post turbo. Yep, this is what I was getting before CW moved the sensor to the pre turbo position. Link to comment Share on other sites More sharing options...
Paul Posted June 2, 2006 Share Posted June 2, 2006 Got mine post turbo too cause I'm a coward Link to comment Share on other sites More sharing options...
RobSheffield Posted June 2, 2006 Share Posted June 2, 2006 mine is IN the turbo i have never seen above 850 Link to comment Share on other sites More sharing options...
MONKEYmark Posted June 3, 2006 Share Posted June 3, 2006 i had 1050 degrees most.on stock jap pump.since having walbro fitted it dropped loads about 800 probe in manifold runner next to cam gears fitted by CW Link to comment Share on other sites More sharing options...
jason m Posted June 3, 2006 Share Posted June 3, 2006 I don't know where mine is - I see about 900c max. It was fitted at Matt H's. Matt any ideas where it was plumbed in? Link to comment Share on other sites More sharing options...
Pig Posted June 3, 2006 Share Posted June 3, 2006 For your reference, I have reached 850 twice on my car now (since being single) the first time i had to pull over as i was smoking loads and the second time i started leaking loads of coolant! I would say terry is corect with the post turbo result! Link to comment Share on other sites More sharing options...
Guest supra01 Posted June 3, 2006 Share Posted June 3, 2006 Ummm Boring Link to comment Share on other sites More sharing options...
Paul Posted June 3, 2006 Share Posted June 3, 2006 Ummm Boring Ummmm, Penis Link to comment Share on other sites More sharing options...
Kopite Posted June 3, 2006 Share Posted June 3, 2006 Ummmm, Penis Link to comment Share on other sites More sharing options...
Pig Posted June 3, 2006 Share Posted June 3, 2006 Ummm Boring WTF??? Link to comment Share on other sites More sharing options...
Miguel Posted June 4, 2006 Share Posted June 4, 2006 For your reference, I have reached 850 twice on my car now (since being single) the first time i had to pull over as i was smoking loads and the second time i started leaking loads of coolant! I would say terry is corect with the post turbo result! So you have seen 850C and you are post turbo sensor location ? ..lets take the rule of thumb of 200C difference between pre and post, that would have put you at 1050C! Link to comment Share on other sites More sharing options...
Terminator Posted June 4, 2006 Share Posted June 4, 2006 For your reference, I have reached 850 twice on my car now (since being single) the first time i had to pull over as i was smoking loads and the second time i started leaking loads of coolant! I would say terry is corect with the post turbo result! I have a spare engine should you need it. My EGT sensor is mounted in the no 1 about 3/4 inch from the head. I usually get 750 on boost with the occasional 800. Warning set to 900. I did get a peak of 900 when I had my knackered stock SMIC, since fitting a Trust SMIC, things have cooled down nicely. Link to comment Share on other sites More sharing options...
JohnK Posted June 4, 2006 Share Posted June 4, 2006 My EGTs dropped by approx 100c after I fitted the T61. My sensor is in the manifold by no1. With the single, its rare and only on the hottest days, pushing the car, that it goes above 850c. Link to comment Share on other sites More sharing options...
