Chris Wilson Posted December 28, 2003 Share Posted December 28, 2003 Your "least-messy" way sounds a right mess, if you'll forgive me for saying so In tank pumps pull from a well, to help curb fuel surge, are you sure you can get the inlet gauzes of two pumps in this well? Will the support pipe take kindly to having 2 pumps a hangin' off it? Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 28, 2003 Share Posted December 28, 2003 Err. Hang on, what's this "one fuel line to each end of the rail? Where is the return coming off? I can't quite picture this set up, but I suspect I am misunderatnding something along the line. (Excuse pun.... ) Link to comment Share on other sites More sharing options...
Ian C Posted December 28, 2003 Author Share Posted December 28, 2003 It's confusing this, it's almost in real time! I'm getting a HKS fuel rail and I believe they have an inlet at either end and a return in the centre. That clears up one confusion. Hopefully I'm not wrong about the two inlets. If you think it's a mess, say so (well, you did ), I don't mind. Having seen the pump cage and baffled well in the tank, I'm confident the inlet filters will both fit - the well is wide enough for two pumps and their pickups side by side. http://www.mkivsupra.net/resources/injectors/images/fueltank.jpg The cage has a quite beefy metal support for the pump, so a second one on there won't be a problem. I've seen pictures of twin-pump installs, side by side and one staggered above the other with an extension hose, that look neat and secure, so I think it's a clean-looking result. I haven't got piccies of the twin installs to hand unfortunately. http://www.mkivsupra.net/resources/injectors/images/fuelpump_cage.jpg So, that leaves trying to get a second output installed in the top of the pump cage and routing hose to the front of the car. By "least messy" I meant "least pain in the ass to me", not "most aesthetically pleasing from a looks and engineering standpoint" so that clears up the other confusion -Ian Link to comment Share on other sites More sharing options...
