help my cars whining
steve0
Steve do you hear it when parked or moving slowly, when turning the wheel lock to lock? If it does, it sounds like your power steering fluid is either low, has air in the system or the pump is knackered and needs replacing.
Also check that the noise is not coming from the belt that goes to the power steering pump. The pump is located to the front of the engine rhs low down as you stand in front of the car. Top up the fluid first if it is low and see if that does the trick.
got some fluid checked the stick seamed there was hardly any init so put some in but me thinks i may have put too much in how much should actually be in and if i did put too much in will it make a problem oh and theres no noise or anything anymore steerings perfect
