steve0 Posted May 13, 2006 Share Posted May 13, 2006 driving my car home last night i noticed it was making a whining noice which gets louder when i turn the wheels and rev it any ideas only had it a fortnight Link to comment Share on other sites More sharing options...
Nic Posted May 13, 2006 Share Posted May 13, 2006 Steve do you hear it when parked or moving slowly, when turning the wheel lock to lock? If it does, it sounds like your power steering fluid is either low, has air in the system or the pump is knackered and needs replacing. Also check that the noise is not coming from the belt that goes to the power steering pump. The pump is located to the front of the engine rhs low down as you stand in front of the car. Top up the fluid first if it is low and see if that does the trick. Link to comment Share on other sites More sharing options...
jim_supra Posted May 13, 2006 Share Posted May 13, 2006 sounds like your power steering needs bleeding, it's an easy job. do a search on here and you should find plenty of info on how to do it. Link to comment Share on other sites More sharing options...
jim_supra Posted May 13, 2006 Share Posted May 13, 2006 Beaten to it! Link to comment Share on other sites More sharing options...
steve0 Posted May 13, 2006 Author Share Posted May 13, 2006 thought it might be the power steering but would it get louder when i put the foot the down Link to comment Share on other sites More sharing options...
Nic Posted May 14, 2006 Share Posted May 14, 2006 thought it might be the power steering but would it get louder when i put the foot the down Yes as the pump is belt driven from the engine. Link to comment Share on other sites More sharing options...
steve0 Posted May 20, 2006 Author Share Posted May 20, 2006 checked the fluid but all i could see was bubbles on the stick no idea how to tell how the levels low Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted May 20, 2006 Share Posted May 20, 2006 bulbs on the stick would also point to air in the system. Bleed it mate, it cant do no harm Link to comment Share on other sites More sharing options...
steve0 Posted May 20, 2006 Author Share Posted May 20, 2006 so im needing to top it up then what power steering fluid should i use and how do i bleed it cheers Link to comment Share on other sites More sharing options...
Nic Posted May 20, 2006 Share Posted May 20, 2006 so im needing to top it up then what power steering fluid should i use and how do i bleed it cheers See this thread Steve http://www.mkivsupra.net/vbb/showthread.php?t=56684 Link to comment Share on other sites More sharing options...
steve0 Posted May 22, 2006 Author Share Posted May 22, 2006 got some fluid checked the stick seamed there was hardly any init so put some in but me thinks i may have put too much in how much should actually be in and if i did put too much in will it make a problem oh and theres no noise or anything anymore steerings perfect Link to comment Share on other sites More sharing options...
